Plusnet Full Fibre 300 Speeds?
Bluesplayer
I have upgraded to Full Fibre 300.  The upload speed seems fine, but the download speed is pretty dire on both wired and wireless.  I am getting under 90 Mbps wired and around 45-50 wireless.  The service was only activated in the last 24 hours.  Does it take time to fully kick in?
18 REPLIES 18
Fixes: 555
Re: Plusnet Full Fibre 300 Speeds?
@Bluesplayer
Simple answer, No! it goes at the provisioned speed immediately
That sounds like two possible issues
1) re the wired speed, you have a cat5 ( 4 core only )  ethernet cable (or a faulty cable) connected in the circuit . This will limit any speed to 100Mb. All ethernet cables should be cat5e or better.
2) the wireless speed would indicate that you are connected to the 2.4ghz wifi band. Make sure that your wireless device is connected to the 5ghz band
Fixes: 137
@Bluesplayer
Are you using a Hub two?
For the Hub two check the ->Home -->Status page WAN link speed, it should be 1000Mbps.
For the wireless device you might be connecting using the 2.4Ghz band.
Bluesplayer
Wireless is working as intended now.  The tester had connected to the wrong network, an additional network created by NOVA Pods.  So that just leaves the wired side of things.  I shall get some new cabling as the speed does seem to be limited to around 100 Mbps.
markhawkin
All Star
Fixes: 20
With the network cable I would start with cable swapping and replugging.
Sometimes that will sort things.
kenm
I am in the same boat
Full Fibre 300 connected today ( 10th March )
When engineer left I was getting 300-310 to my desktop by WiFi in different room to router
engineer connected new router and cables sent by Plusnet
been checking speeds but this afternoon download suddenly only getting between 75 - 90mbps
upload between 40 - 50mbps
I assumed it would be the 10 day wait but it says NO in above reply
Should i phone in /  only get the wait 10day response.
Kenm
Fixes: 555
@kenm it sounds like your device has disconnected from the 5ghz wireless band and reconnected to the 2.4ghz band. Ensure you device is set to prefer 5ghz.
kenm
Thanks for reply
I was dreading a reply like that I have NO IDEA how to do things like that inside the router.
Everything had gone well engineer managed to get cable thru old ducting, set it all up with new router / cables (plusnet).
He checked with his gadget it was 300 wireless then walked thru house to where desktop computer is it still showed 300 wireless,
he said you have a good wifi signal all over the house, even my wife's donkeys years old ipad was getting 250ish mbps
During the afternoon the router switched off I thought we had had an electric power cut ,but NO
switched router back on manually, all fired up ok Blue light on, now speed has dropped, is that what has caused the problem.
Kenm
kenm
I have just done a test using my laptop Hardwired next to router
Down 144mbps
Up      47mbps
My main desktop is (new w11 27inch ) all in one unit and bit to heavy for me to cart about, with router other side of house.
Kenm
Fixes: 555
@kenm whilst its not unknown for Full fibre to be provisioned on the wrong speeds , its very rare.
So we need to confirm that its not your equipment that's restricting the speeds.
What make & model is the laptop ? does it have a built-in network card or is the connection using a usb network card?
What speedtesting site are you using ? try speedtest.net if you arent already
kenm
just been doing some testing strange results
I have a HP laptop
and a Lenovo all in one desktop
I have done a reset of the router password on both machines
both are next to each other in different part of house to router using wifi
LAPTOP Plusnet speed test x2 result D 250  U 43 / D 240  U 46
When i go into network/internet settings its properties are 5GHz
DESKTOP Plusnet speed test x2  D 51  U46 /  D57  U 43
Network/internet settings its properties are 2.4GHz
Looks like problem with my DESKTOP Wifi        Kenm
Fixes: 555
Yes, you need to get teh Desktop to use the 5ghz band. The 2.4ghz band will limit the download speed.
kenm
Where can i get info on how to get it up to the 5GHz band
Kenm
Fixes: 555
Assuming its Windows 11 , then there should be an option in the Network Adapter properties to 'Prefer 5ghz'
kenm
Did some searching thats what kept coming up
Network Adapter Properties allow prefer 5GHz
I have been going over my pc all afternoon  but cannot find that preference anywhere
pc only a year old with w11,
Screenshot of my internet/network settings
Will have to get local PC guy into have a look
Thanks Kenm
