Ping variability
PhilipHeyes
Seasoned Champion
Fixes: 28
Re: Ping variability
Open a Command Prompt and type :
ping -n 25 dns.google
Fixes: 392
@Lasanthan I suggest you follow this guide: https://www.lifewire.com/how-to-open-command-prompt-2618089 , as it is comprehensive, but if you still have problems, post back.
Lasanthan
Ping statistics for 8.8.8.8:
Packets: Sent = 150, Received = 150, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 6ms, Maximum = 127ms, Average = 22ms
Fixes: 392
So, for Google, the figures are good. What would be interesting to see is the results for a site where you are seeing problems.
corringham
Seasoned Champion
Fixes: 23
I'm not sure they are - min of 6ms may be OK, but max 127ms, avg 22ms shows a lot of variability.
For my own FTTP (not Plusnet) the maximum is under 5ms.
Fixes: 392
@corringham I agree with you actually.Now I've fully woken and had a load taken off my mind (personal stuff), I'm wondering if a tracert would give us more information.
One to affected  sites would be useful.
markhawkin
Champion
Fixes: 22
"The Openreach network isn't the problem here - it is the actual routing of the network (PN's or SKY's) which is different."
I get that point. I would, however, start from both networks being fairly decent and, if anything, suspect the BT network which Plusnet (generally) uses would be the better of the two.
I would be interested to know if the high average ping was wired or wireless? If wired and using the Plusnet Hub something odd is happening.
ExForce9
All Star
Fixes: 11
@jab1 wrote:
... I'm wondering if a tracert would give us more information.
@Lasanthan
Can you produce a trace like the one shown below, to a target IP address that is giving you problems ?
This type of trace can show where delays occur, packet losses, and the range of best to worst latencies at each network hop.
This example is my MTR trace of 100 ping responses (in milliseconds) from my VDSL router to Google DNS <8.8.8.8> -
                                 Loss%   Snt   Last   Avg  Best  Wrst StDev
  1.|-- 192.168.69.1              0.0%   100    0.2   0.2   0.1   0.3   0.0
  2.|-- ***                       0.0%   100    5.7   5.7   5.5   6.1   0.1
  3.|-- ***                       0.0%   100    5.6   5.7   5.5   6.7   0.2
  4.|-- 72.14.219.80              0.0%   100    7.3   7.4   7.0   9.2   0.3
  5.|-- 209.85.253.95             0.0%   100    5.8   5.8   5.5   6.2   0.2
  6.|-- 172.253.65.209            0.0%   100    6.7   6.6   6.2   8.5   0.3
  7.|-- dns.google                0.0%   100    5.7   5.7   5.5   6.2   0.2
Lasanthan
Thank you for all the contributions and apologies for the delay in replying. But my connection has been stable since having the Plusnet router with the WiFi off and my Deco BE26 units acting as access point.
Are there any settings that would be needed for my Deco units to used as the main router instead.
Could that have been issue beforehand?
markhawkin
Champion
Fixes: 22
To remove the Plusnet router you would need to set the WAN facing Deco (I guess that's the "master") to have your account credentials (username and password - no need for VLAN tags) and be set to PPPoE.
There is some suggestion that PPPoE on the Deco doesn't work so well (there is an overhead in maintaining the PPPoE session) do a search for Deco and PPPoE.
If it's working OK I might be tempted to leave well alone....
