Optical Network Termination
JohnFol1
Hi there, 1st engineer visit to house done and "cable" to outside of house is now in place. I can see from PlusNet the next visit is to fit an Optical Network Termination "socket" inside the house.
The original phone line enters the house under the stairs however I've diverted it to my garage.
However there's no ducting so I'm anticipating Openreach will place the ONT in the house and I assume it'll be under the stairs.
Given there's no power or possibility of power in the cupboard, do I have any options or do I need to cancel the order?
14 REPLIES 14
mike600
Re: Optical Network Termination
You need to think of some alternative location(s), as if there's no power, it will not work.
JohnFol1
Thanks Mike.
Would Openreach route cable through the house?
Fixes: 586
They will supply up to 10m of internal fibre and will clip to skirting boards/door surrounds etc but will not drill through internal walls.
TheRealDabhand
They did eventually drill through my wall when I had the 2 month problem of trying to get mine done, I think this was because there was literally no other way to do it to get it into the house, and if others in my block 2 floors above me need it it has to go through the ceiling of my cupboard into theirs and further to give them it too. Just based on the layout of my home and where the cable came into the building from outside.
So maybe there is a bit of hope for the OP?
mwwagain
Fixes: 4
What is through the wall from where the incoming 'cable' ends - I assume at a grey CSP box ?
That would be their first choice - drill outward to just above the CSP.
You don't need your router/hub there - just one mains outlet and then to run your own ethernet to where you want the router.
markhawkin
Champion
Fixes: 22
@JohnFol1
You need to work out an achievable way of getting what works for you.
The ONT needs power and as the engineer will leave it the router will probably need to be nearby and powered.
You can run a cable from the ONT to a different location for the router but that's for you to arrange (an electrician may be able to run network cables).
If the phone line master is in the garage and that's a sensible fibre route and has power you could try getting the ONT there. You then either need to have the router there or extend the ONT to router cable to wherever you want the router.
JohnFol1
Thanks Mark
As long as the fibre cable ends up somewhere with power I can handle the router.
Sounds like my only option is for OpenReach to extend the outside cable to the garage.
It's about 4m and I guess I'll need to put some ducting in to protect the fibre cable.
Also sounds like I need to tell PlusNet so engineer is expecting the work
JohnFol1
mwwagain, inside the house where he fitted the grey box is the back of a cupboard with no hope of any power.
I think I need them to extend the external fibre to the garage where there is power.
mwwagain
Fixes: 4
A 4m ground level trip around the outside should be fine - the 'cable' comes in a few specific lengths with the ONT-end plug fitted and they have a stock in the van.  I do not see any need to tell PlusNet unless you were over say 10m.
I can see plenty of far longer CSP to 'hole in wall' runs on neighbours houses, like 5m up and 7m to rear at height.
I had an in-garage instal for just the ONT.  On the day I had a mains extension for a laptop and the PlusNet Hub sat on top of the freezer to get the setup proved.
As the OR chap did the fibre bits, I was wiring in the LAN dropper.
Fixes: 118
@JohnFol1
You can always get an electrician in after the event to install a new wall socket beside the ONT. An extension lead would work to get you up and running.
Same with the internal cabling. Do whatever is required to get you up and running and then sort out the cabling afterwards. A recent thread had both the CSP and ONT inside the garage and the OP looking to sort out ethernet cabling afterwards.
You just need to look at all possibilities and then talk to the engineer on the day to see what's possible. They'll work with you if they can. The attached picture shows an external duct run in advance where the engineer was happy to run the fibre through it into the loft where both the CSP and ONT were installed. It saved them having to run the fibre to ground level and drill though a wall. The OP also had run ethernet from the loft to his router location.
Fixes: 118
@JohnFol1
In post #9 you say the CSP (grey box) is inside the house in a cupboard. Is this correct?
This may help with the ONT location. If you install internal ducting to where you want the ONT (with draw string in place if required) the engineer will almost (???) certainly be happy to use it as there's no power source beside the CSP.
Just be aware they could still say no, not happy so your work would have been in vain.
RobPN
Fixes: 15
Not necessarily.
The ONT does not have to be powered by a nearby mains socket, it can be powered via PoE or even by extending the 12v power lead by a few metres and that conduit could be used to route such cables.
There are threads on the forum describing how members have achieved this.
e.g.   https://community.plus.net/t5/Full-Fibre/ONT-Power-over-the-Ethernet/m-p/2044948/highlight/true#M306...
and
https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/ONT-extension-DC-power-cable-and-Fibre...
Edit:  swapped second link to go straight to relevant post
Fixes: 118
@RobPN @JohnFol1
Agreed re the power options.
The OP could also consider relocating the ONT after the install.
https://www.premitel.uk/consultancy/expert-advice/how-to-relocate-the-ont-fibre-termination-point/
SixCopperKs
Fixes: 4
Dunno if this helps, but Openreach placed my outside (CSP) where it was convenient for the dropwire and its street access, then ran the premises fibre from the CSP externally about 10m horizontally and 3m vertically for me. (Only 10 minutes of ladder work for Openreach from the neighbour's side path, easily OK’d with absent neighbour.)
My ONT position was on the inside of the upstairs external wall, so there is a very short hop from the wall entry hole to the ONT.
For @JohnFol1 's situation it sounds like running the cable externally from the CSP to the outside wall for the garage ONT might well be simple enough if they can fix it to a wall all the way to a convenient point for your garage, assuming the garage is still a convenient point where all your current router's connections spread out. As long as the distance inside the garage (to where your ONT and power can be) isn't huge then that might work nicely for you. The inner (white) fibre cable to the ONT is quite slim and not as stiff as its black external-only cable sheath (which is NOT combustion-safe for internal areas). But the white part is not particularly robust so Openreach / its contractor won't want to run it very far internally nor drill internal walls. If your current router is inside your garage, or on existing ethernet cable,  then it should be simple enough to put your ONT on the garage outside wall by the hole and run your ethernet cable to whereever your current router is conveniently positioned.
