No option to order new router
Oddjob62
I requested an upgrade to full fibre, and on the confirmation email it says:
"If you've ordered a Plusnet router, this will arrive before your activation date. Please refer to the guide inside the box for setup instructions."
Unless i completely missed it during the upgrade request process, there was no place to request a new router, are they sent out automatically? or do i have to request one separately?
2 REPLIES 2
Fixes: 137
Re: No option to order new router
@Oddjob62
The Hub supplied with Full Fibre is the Hub two.
Do you already have a Hub two with your current product? If yes, that might explain why you were not offered a new Hub.
Oddjob62
Ahh yes it is a Hub two (with WAN port). Thanks for the quick reply @Dan_the_Van
