No option to order new router
FIXED- Subscribe to RSS Feed
- Full Fibre
- No option to order new router
09-03-2026 11:50 PM
I requested an upgrade to full fibre, and on the confirmation email it says:
"If you've ordered a Plusnet router, this will arrive before your activation date. Please refer to the guide inside the box for setup instructions."
Unless i completely missed it during the upgrade request process, there was no place to request a new router, are they sent out automatically? or do i have to request one separately?
Fixed! Go to the fix.
10-03-2026 7:43 AM
The Hub supplied with Full Fibre is the Hub two.
Do you already have a Hub two with your current product? If yes, that might explain why you were not offered a new Hub.
Re: No option to order new router
11-03-2026 6:04 PM
Ahh yes it is a Hub two (with WAN port). Thanks for the quick reply @Dan_the_Van
- Full Fibre
