No broadband connection
jan
I woke up this morning and have no broadband connection. The hub two showed a page with troubleshoot button on it. When I click on that I end up with this... see attached image
I can login to the hub two router but it just says disconnected & offers no tools for reconnection or diagnosis.
Just adding some extra detail. We're on a full fibre connection to a hub two which has been fine for 6 months. On the status page it says No service, rather than disconnected.
8 REPLIES 8
RealAleMadrid
Fixes: 68
Re: No broadband connection
@jan  A bit more information would help, what are the indicator LEDs on the Openreach ONT showing? It sounds like you have lost the incoming fibre connection. So nothing to do with the router.
jan
There are three solid green lights on the ONT
Power PON & LAN are solid green LOS is unlit
RealAleMadrid
Fixes: 68
@jan  So the ONT is connected and lights are normal, not much you can do apart from rebooting the router, if you haven't tried that already.  If that doesn't help you will have to contact Plusnet support.
ClaudiaG23
Fixes: 25
Hi @jan  I can see you've spoken with one of our Technical Advisor's this morning and an engineer is booked to visit your property tomorrow between 8am and 1pm.
 Claudia Garner
Fixes: 1,495
Moderators Note
This topic has been moved from Broadband to Full Fibre
jan
When I got up this morning service had resumed sometime overnight.After re-applying my personal config to the router (after factory reset yesterday) everything is working again.
I cancelled the engineer over SMS.
Thanks.
RealAleMadrid
Fixes: 68
@jan  Good that it's working but rather worrying that it happened, you certainly don't want it happening again. I wonder if Plusnet can give any explanation for the problem.🤔
willcutforth
Fixes: 113
There is an issue in the are by the looks of it @jan and the fault is still open but doesn't need an appointment. That's as much as I can give at the moment unfortunately.
 Will Cutforth
