No DSL light on Openreach modem
FIXED- Subscribe to RSS Feed
- Full Fibre
- Re: No DSL light on Openreach modem
05-02-2019 4:33 PM
Is it possible to have my modem checked out remotely. I don't actually have a house phone to check if I'm getting a dial tone at all, although I've been told the line is fine.
Thanks.
Fixed! Go to the fix.
05-02-2019 4:58 PM
Sorry to hear you're having connection issues following moving house.
Our tests aren't showing the cause for the problem so we'd likely need to arrange an engineer visit to further investigate this.
Before we go down that path can you confirm you've tried plugging your router into the test socket as explained Here? If you're still having issues connecting that way, I'd recommend reporting a broadband fault to us at http://faults.plus.net
Let us know how it goes.
05-02-2019 5:15 PM
05-02-2019 5:19 PM
Try plugging a phone into it, do you get dial tone? Does it give the correct number when you dial 17070?
05-02-2019 5:23 PM
No worries, I'd definitely try @Mustrum's suggestion to figure out if there is dial tone and if you've got the right number. This will determine if there's a crossed line and/or the phone line is faulty and will help us in choosing the right fault path when reporting this to our suppliers.
Regarding your master socket can you post up a photo?
06-02-2019 9:11 AM
After tracing the phone wiring into the house, I found another master socket hidden in the hall that works. It doesn't appear to be connected to the master socket in the living room or the other extension socket. Maybe those two are from an old second line.
Anyway, thanks for the advice. Helped me narrow down what the source of the problem could be.
06-02-2019 12:03 PM
Hi @soclanat,
Thank you for getting back in touch. I'm pleased to hear that you have found another master socket in the property and that your broadband is now up and running after connecting to that.
Please let us know whether there's anything else that you'd like to discuss.
- Full Fibre
