New FTTP very slow
bikeman
New FTTP very slow
Upgraded to FTTP done today.
At the moment the download speed is less than 3 yes 3 Mbps. Upload is 19 Mbps. I used to get 45Mbps on the old FTTC.
Will it improve or should I ask the engineer to come back?
34 REPLIES 34
Fixes: 387
Re: FTTP very slow
That does not make sense - did the installer not verify the connection was good before they left? Which port on your Hub is the ONT connected to?
bikeman
Re: FTTP very slow
The ONT is connected to the router WAN port as it was before. I never saw the installer carryout any tests.
bikeman
Re: FTTP very slow
Fixes: 585
Re: FTTP very slow
Is this a wired test ? i.e device connected via an ethernet cable to the router
Fixes: 387
Re: FTTP very slow
If you were previously on FTTC, you should not have been connected to the WAN (red) port on the Hub
bikeman
Re: FTTP very slow
no its from the laptop wifi, as before
bikeman
Re: FTTP very slow
The router is connected to the ONT correctly
Fixes: 585
Re: FTTP very slow
Unless the OP had a separate DSL modem
Fixes: 585
Re: FTTP very slow
@bikeman can you try a wired test just to prove whether its the connection or a wifi problem ?
bikeman
Re: FTTP very slow
He has simply changed the NBN ( I think thats what its called) for an ONT
bikeman
Re: FTTP very slow
Wired connection is same
Fixes: 387
Re: FTTP very slow
OK, @MisterW . As they haven't said which router they are using.... But I'll leave this to you.
Fixes: 585
Re: FTTP very slow
@bikeman  so what connection did you have before ? and from which ISP ?
What router were you using before ? and what router now ?
bikeman
Re: FTTP very slow
Its PLusnet, hence me posting here. Heres the old box.
and heres the new
Both use same Hub2 router
