New FTTP very slow
Fixes: 569
Re: FTTP very slow
@bikeman
so you had FTTC before ( that looks like an HG612 VDSL modem ) and you've changed to FTTP
Is the router the same actual router ?
If you go to the router troubleshooting -> helpdesk page , does it show your correct username ( and not [email protected] ) ?
bikeman
Re: FTTP very slow
I dont want to be rude but I did say in my OP and subsequent posts, that the upgrade was from FTTC to FTTP, using same hub 2 router.
I've used the Plusnet bot, which has confirmed that there is a fault. This is very poor.
Fixes: 374
Re: FTTP very slow
I know I said I was leaving this to @MisterW , but I am confused.My understanding is that the PN bot does not work on  an FTTP connection, and I am a little surprised, to say the least, that the installer didn't confirm the connection was stable before leaving.
Fixes: 569
Re: FTTP very slow
Apologies, I see you did say you got 45Mb on FTTC. As to the router, Plusnet usually insist on supplying a new router with FTTP. Since you are only doing wireless tests, in confirming whether it was the same physical router, I was trying to rule in/out a new router using a different wireless channel.
As @jab1 says, the installation engineer should have confirmed the connection was working before leaving. As to having a fault which gives low download speed but good upload on FTTP. I'm intrigued, because FTTP usually works at the provisioned speeds or it doesnt work at all!
One cause seen for low download is where the Plusnet account isnt active and the Hub is still using the setup id. Since this is an upgrade on the same account, that shouldnt be a possibility!.
Is the PON light on the ONT steady and the LOS light off ?
NB don't let support fob you off with the 'leave it for 10 days whilst the line settles' , that's rubbish for FTTP , there is no training period , it goes at the provisioned speed immediately.
Fixes: 109
Re: FTTP very slow
@bikeman
Unfortunately many people get confused between Fibre (FTTC) and Full Fibre (FTTP). When trying to help forum members generally ask for clarification as to exactly what service your receiving and what equipment you're using.
They then may be in a position as to offer advice.
Two bits of advice have already been offered. Use a wired connection to test your speed. PN only guarentee the speed received at the ONT and not any subsequent WiFi signal.
Secondly you were asked to check you router admin page to see what login PN are receiving. If it's "setup" rather than your id this can cause problems.
bikeman
Re: FTTP very slow
Lights on ONT are as you can see in photo above, 3 steady, LOS off.
Wired speed test is only marginally faster. Again previous post did say this.
The router is unchanged, ie the login hasnt been touched and is using my login.
Fixes: 569
Re: FTTP very slow
@bikeman in that case you have an unusual fault and you'll need Plusnet support to sort it out.
bikeman
Re: FTTP very slow
Unusual? More likely the clown who installed this didnt terminate the optical connector to the fibre correctly.
Fixes: 472
Re: FTTP very slow
@bikeman
Have you tried a factory reset on the hub? Push a paperclip or similar in the reset hole and hold the switch closed until you get a green light.
Fixes: 569
Re: FTTP very slow
I'm afraid we're all at the mercy of Openreach and the contractors they employ to do the installations. They're paid by the job and so there's an incentive to complete as quickly as possible.
The installation doesnt look too clever.  Normally the fibre exit to the outside goes via a plastic hole cover/protector which controls the bend radius. Its normally to the side of the ONT. Your's seems to exit behind the ONT ?
Having said that, a fibre fault would normally show as an LOS light on the ONT or just possibly a flashing PON
In addition to @Baldrick1 s suggestion , a power cycle of the ONT is worthwhile (if you haven't already tried it )
mystreet1
Seasoned Pro
Fixes: 7
Re: FTTP very slow
@MisterW
Looking closer at the ONT it appears that it may be mounted over a sunken 1g outlet that was possibly used for the 'old' master socket which has been removed. Hence the cable coming out of the back of it.
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
Re: FTTP very slow
I can't offer any help with this particular issue, but it seems as good a place as any to ask about the TLAs that relate to an ONT:
I'm fairly sure that:
ONT = Optical Network Terminator
LOS = Loss of Service, (ie off is good)
LAN = Local Area Network
But what does "PON" stand for and mean please?
Also, if I have any of the others wrong, please correct me - thanks!
RealAleMadrid
Fixes: 68
Re: FTTP very slow
@Anonymous  PON is Passive Optical Network which is what Full Fibre is. Steady PON light means connected to the network, flashing means trying to connect so a possible failure mode.
Fixes: 374
Re: FTTP very slow
@Anonymous This is from an American site, but explains 'PON' - https://www.juniper.net/us/en/research-topics/what-is-pon.html
bikeman
Re: FTTP very slow
According to Plusnet it takes up to midnight for openreach to complete and notify plusnet.
I think we'll call that a fob off.
