National Lottery Website.
buseng12
Re: National Lottery Website.
How much more convincing does P/N want?
Falling on deaf ears seems appropriate.
Just to mention that I have now made a formal complaint to Camelot citing P/N & their network blocking access to their (National Lottery) website.
Still awaiting their response as I only sent it late last night.
AndyH
Quote from: buseng12
Convincing of what? Plusnet (Bob) believes you, when you say you cannot access the site.
Unfortunately, the National Lottery website does have a history of being a pain when it comes to geolocation. Other ISPs like TalkTalk, Sky and even AAISP have had exactly the same issue before (and these were from IPs issued by the European register, RIPE).
I am assuming the National Lottery site still uses Neustar as their geolocation service provider. The IP ranges in question do show on the Neustar as being geo-located in the UK, but if you contact the National Lottery site directly they can explain if there are other factors involved.
buseng12
@AndyH.
Just read through this forum for the last week, lots of people have now mentioned that they cannot access the N/L website through P/N but are able to do so either by mobile networks or other isp's
Convincing enough?
I accept not every P/N user is affected but the common factor seems to be whatever ip address you have & maybe which gateway as well.
The new network & 143/146 ip's seem to be the worst.
Is this proof I have been switched over?
If so the dates tally up, (a) Lottery site problems
                                        (b)  When my O/R modem re-synced & dropped my speed by 7-8 meg. (topic elsewhere).
                                                http://community.plus.net/forum/index.php/topic,147815.0.html
AndyH
I'm not sure what you think people need convincing about, as no one is doubting what you're saying when you cannot access the N/L website.
It's not clear whether this is down to a routing issue or the N/L site blocking certain IPs. At least previously with those Infonet IPs, you could access the site but were unable to buy a ticket due to incorrect geo-location.
Being moved on to the new Plusnet network would have no bearing on your connection to the cabinet - this is completely different. As you posted in another thread, you have interleaving turned on the downstream/upstream (I believe) which will down to the stability of your connection and the number of errors on your line.
buseng12
Slight more info, this is my gateway.
You are currently connected to gateway pcn-ar01.
This is located in Colindale Point of Presence
nbk
I don't see why 146 addresses would suddenly become an issue
I've been using the 146 infonet IP's nearly exclusively for about a year (since they're always assigned on the gateways I don't have speed issues on) and havent had any issues accessing the lottery website until recently.
AndyH
Here are my traceroutes (same issue NL site doesn't load/connect at all on the new network).
Via the new network:
Tracing route to www.lb.national-lottery.co.uk [194.246.78.103]
over a maximum of 30 hops:
  1    1 ms    1 ms    1 ms  dsldevice.lan [192.168.1.254]
  2    *        *        *    Request timed out.
  3    *        *        *    Request timed out.
  4    3 ms    3 ms    5 ms  172.17.3.205
  5    5 ms    4 ms    4 ms  172.17.10.130
  6    7 ms    4 ms    5 ms  be2.pcn-ir01.plus.net [195.166.129.164]
  7    5 ms    5 ms    4 ms  core1-BE1.colindale.ukcore.bt.net [195.99.125.132]
  8    5 ms    7 ms    7 ms  peer1-et-1-3-0.telehouse.ukcore.bt.net [195.99.127.19]
  9    *        *        *    Request timed out.
10    *        *        *    Request timed out.
11    *        *        *    Request timed out.
Via the old network:
  1    <1 ms    <1 ms    <1 ms  router.asus.com [192.168.1.1]
  2    4 ms    4 ms    4 ms  lo0.10.Central10.ptn-bng02.plus.net [195.166.130.190]
  3    4 ms    4 ms    4 ms  irb.10.PTW-CR01.plus.net [84.93.249.1]
  4    5 ms    5 ms    4 ms  linx-ge7-0-oscar.lon.router.colt.net [195.66.224.49]
  5    *        *        *    Request timed out.
  6    *        *        *    Request timed out.
jockwav
My IP has changed tonight to 146. is that me on this new server now?.
My uptime changed to 25 mins, & my connection speed has changed from 37.5 D TO 11.75 Down,not happy at all. Shocked Huh Huh
http://beta.speedtest.net/result/5005599480
Getting worse.
http://beta.speedtest.net/result/5005611019
https://www.flickr.com/photos/james_bingham/
AndyH
Do a traceroute and see if you have 172.* addresses as 4th/5th hops.
nbk
Quote from: jockwav
Getting worse.
So your slower speeds are just on the speedtests and not modem? You could try another server (i always use vodafone in london so always to the same place) or it could be the gateway you're on.
buseng12
Quote from: AndyH
My traceroute is almost exactly the same on the new network, the only difference is that I have an extra timeout at No4 so everthing is moved up one after that.
Strange the old network shows a much smaller "path".
bobpullen
Fixes: 330
It shows a smaller path because the hops over the Wholesale network are masked by L2TP tunnelling.
rnedwards
Same problem here. I can access the National Lottery website no problem if I switch to my mobile hotspot (Three UK).
buseng12
How many people are reporting this now?
Yet "wonderful" P/N are doing absolute zilch about it.
Just getting fobbed off with excuses.
It's fairly certain it ties up with this new network nonsense.
Unfortunately Camelot haven't responded to my email yet I sent at the weekend.
Hope P/N are going to refund everyone's mobile data costs who are affected.
AndyH
No one is fobbing you off and Plusnet are investigating and looking at it, as per Bob's post:
Quote from: Bob
Those on dynamic IP's who have been moved to the new network probably won't be able to get away from the 143 IP's at the moment. We're aware of the National Lottery issue though and we're looking into it. Not sure if it's actually anything to do with the new network mind you.
Edit: ref: 89836
