Problems with Draytek Router
joelanon
Hi all
I am trying to configure a Vigor Draytek 2850 VDSL router but cannot get it to connect. I have tried it both with and without the openreach modem ( i know this shouldn't be needed).
When i go into WAN status i constantly get the message 'PPP Shutdown' On the draytek website they say this is down to incorrect username and password - but when i use these details on the standard plusnet router it works as it should.
This is getting proper frustrating now as i've used draytek routers in work for a while without any issues.
Thanks guys
Tags (2)
2 REPLIES 2
Mustrum
Fixes: 81
Re: Problems with Draytek Router
Have a look at this old thread, it should help you with the settings.
markhawkin
Champion
Fixes: 22
@joelanon
The following two links may be of interest.
http://www.draytek.co.uk/information/our-technology/bt-sin-498
https://www.draytek.co.uk/upgrade/
I believe there are problems with the 2850 and fibre connections (unless the Openreach modem is used).
Draytek have a helpful page on fibre and a modem.
http://www.draytek.co.uk/support/guides/kb-btfttc-openreachmodem
