National Lottery Website.
- Full Fibre
- National Lottery Website.
Re: National Lottery Website.
18-01-2016 1:41 PM
Quote from: rnedwards Same problem here. I can access the National Lottery website no problem if I switch to my mobile hotspot (Three UK).
Likewise, all weekend (since Friday when I first tried). I have just now successfully connected, though.
No other sites I've accessed have been affected. #
Annoying for the lost time.
18-01-2016 2:19 PM
This is NOT Plusnet's fault.
They are giving you an IP address which is correctly identified as being in the UK. The organisation at fault is the National Lottery who, in spite of being contacted several times, are using an out of date geo-location lookup.
18-01-2016 2:35 PM
Even with my foreign VPNs, I can access/connect to the NL site.
18-01-2016 2:40 PM
In that case one might expect other sites to be inaccessible via the new network.
18-01-2016 2:56 PM
Quote from: spoon
Yes there are two different things here, one is accessing the site which you should be able to do wherever you are in the world.
The other which IS more geographical, is whether you can actually play or not. This is being in the UK dependant.
@allegoricus, You must of struck lucky! Still not working here.
18-01-2016 3:19 PM
Tracing route to www.lb.national-lottery.co.uk [194.246.78.102]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.1
2 6 ms 6 ms 6 ms 172.17.0.176
3 6 ms 6 ms 6 ms 172.17.4.190
4 12 ms 11 ms 11 ms 172.17.10.230
5 11 ms 11 ms 11 ms be2.psb-ir01.plus.net [195.166.129.180]
6 11 ms 11 ms 11 ms 195.99.125.134
7 12 ms 12 ms 12 ms peer1-et-2-1-0.telehouse.ukcore.bt.net [62.172.1
03.25]
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16
A tube of smarties for whoever sorts it out....
18-01-2016 3:48 PM
Quote from: spoon Lets get one thing straight:
Ehh...
I've been using the 146 infonet addreses for a year which a lot of places identify as being in the US and I've not had an issue with the lottery site at all. The fault is either with plusnet or whoever they peer with
18-01-2016 4:17 PM
When I use my Three MiFi (whose gateway is, I think, in Belgium), I get connected to the NL site OK, but get challenged to verify that I'm in the UK when I log in..
I'm never unable to connect to the site via Three.
Anyway, things appear to be OK now and, FWIW, I only came here after the event, seeking an explanation.
19-01-2016 12:18 PM
And should be fixed in the next couple of days.
19-01-2016 1:14 PM
19-01-2016 3:50 PM
Finally heard from Camelot about the P/N access issue I contacted them about.
Basically they said they are aware of it, then get this: suggested I reboot my router!
I've done that more times than I have had hot dinners lately to try & get a decent ip address.
"We are aware that some PlusNet users are experiencing issues accessing The National Lottery Website. We are investigating this but in the meantime a reboot of your router may resolve the issue".
19-01-2016 4:03 PM
Quote from: Chris
As Chris has said, it should be fixed within the next couple of days.
19-01-2016 4:20 PM
mav:quote
19-01-2016 4:35 PM
19-01-2016 5:02 PM
