Loss of internet
FIXED- Subscribe to RSS Feed
- Full Fibre
- Re: Loss of internet
02-12-2025 7:46 PM
Anybody else had something similar or know what else to try?
Fixed! Go to the fix.
02-12-2025 7:50 PM
What colour is the LOS light on the ONT?
02-12-2025 7:51 PM
02-12-2025 7:52 PM
02-12-2025 7:55 PM
So, there is a solid connection to the ONT. The issue is the connection between the ONT and the router. What username is displayed on the Hub?
02-12-2025 7:58 PM
02-12-2025 8:01 PM - edited 02-12-2025 8:02 PM
02-12-2025 8:06 PM
02-12-2025 8:13 PM
If the lights on the ONT are three solid green and your credentials are correct, then it is a Plusnet problem. Try a full factory reset of the Hub - Again.
03-12-2025 12:36 AM
Gave it one final try. Reset hub then left and then reset the ONT.
It’s a miracle I am connected!!! I did it after midnight I wonder if Plusnet reset my connection?
Who knows who cares now. Thanks
03-12-2025 7:08 AM
Glad you are connected. I doubt PN would reset your connection that late in the day, they don't have staff on that late in the day.
03-12-2025 8:57 AM
Absolute speculation but Openreach run their configuration tasks (it used to be called "the robot" but I don't know if it still is) after midnight.
A configuration "push" may have been the fix.
