Losing fixed IP on package change?
g0uex
I was just about to upgrade to full fibre and I have a fixed IP I have had for years. I am getting conflicting information as to whether I would keep the IP or lose it.
One person on customer support said I would lose it by switching packages and the other said I would not lose it because it is tied to the account and not the package.
Has any one else been through the same process?
4 REPLIES 4
Fixes: 384
Re: Losing fixed IP on package change?
The second agent was correct.
g0uex
Thanks for that, I am just waiting for written confirmation from the tech dept.
If I cant keep the IP I do not want to upgrade and will start looking for a new provider.
Fixes: 384
@g0uex You DO keep the fixed IP if you upgrade, I can promise you.
g0uex
All confirmed in writing and the order has been reactivated.
Thanks for the quick response.
