Latest on FTTP?
Fixes: 105
Re: Latest on FTTP?
@themcgarvie
The last unofficial news was they were to launch around now but any number of things could delay this. Until there's an Official Announcement we won't know.
https://www.ispreview.co.uk/index.php/2021/04/broadband-isp-plusnet-uk-predicted-to-launch-fttp-this...
Use the folllowing to confirm FTTP is coming. The first will tell you in due course when it's available to order.
https://www.openreach.com/
If FTTP becomes available to you before PlusNet lauch then they have been waiving early termination fees if you move to BT or EE (but don't quote me on this).
Leapy
Seasoned Champion
Re: Latest on FTTP?
That didn't happen to me Undecided I went to FTTP with BT and PlusNet cut off my internet access but left me the phoneline two weeks before the move! Then I had a terrible time trying to get any internet connection Embarrassed.
SteveA
Re: Latest on FTTP?
OpenReach have now basically moved from "Ultra fast coming soon" for our street to "No we've no plans at all to move any of you off FTTC with copper runs of neatly 1Km"
So I'm basically stuck with 44 down for the foreseeable future or moving to Youfibre (who are getting closer and closer) who will do a full fibre install to my house.
Leapy
Seasoned Champion
Re: Latest on FTTP?
@SteveA  that's very disappointing for you, hope it's not too long.
Fixes: 105
Re: Latest on FTTP?
So, the rumoured new PlusNet router is either out or is about to be released.
https://www.plus.net/help/broadband/router-information/
RRM
Re: Latest on FTTP?
Hub2? Doesn’t seem like much of an improvement, fewer Ethernet ports no 802.11ax. Single SSID, might be problematic for IOT devices.
brianbelfast
Re: Latest on FTTP?
I think it's reasonable to stick to the old assumption that, if it's supplied free it's gonna be pretty useless.  That goes for most ISPs. Not just Plusnet.
Leapy
Seasoned Champion
Re: Latest on FTTP?
Isn't this the same specification and the £200 BT Smart Hub2? https://shop.bt.com/products/bt-smart-hub-2-097683-DYNK.html
I'm running the BT Smart Hub2 with BT FTTP and it's OK.
brianbelfast
Re: Latest on FTTP?
Yes the same spec.  It'll probably work fine for you as long as you're hard wired to one of the ethernet ports. Problem is though, it kinda defeats the purpose supplying this router with the likes of the BT 900 FTTP package because it doesn't support 802.11ax (wifi 6).  Much better to ditch it it in favour of a snazzy new mesh system. That's my opinion anyway.
Leapy
Seasoned Champion
Re: Latest on FTTP?
@brianbelfast funny you should mention Wi-Fi 6 as I've just (last week) upgraded my PC and added Wi-Fi 6E and was gobsmacked when it's as fast (150mb down / 30mb up) on WiFi as on the ethernet cable.Shocked
brianbelfast
Re: Latest on FTTP?
That's good to hear. Yes a big improvement.  Friends of mine have the BT 900 package, with that smarthub thing, and they might as well not have bothered.  The fastest they are getting on any of their wifi devices is 400-450, and barely half the house has wifi coverage. When I mention mesh they look at me like I'm mad.
barnyandpippa
Re: Latest on FTTP?
I still have the original Netgear router that came with the trial. I abandoned the WiFi on it long ago and now have a TP-Link Omada system. The access points in the house are all hard wired back to the router but I have an outdoor one on mesh to cover the garden.
The mesh one gives me more trouble than all the others put together so I’d always go wired APs rather than mesh if you can.
brianbelfast
Re: Latest on FTTP?
Yes of-course. To each their own.  It's good that you've found a setup that works well for you.   Multiple hard-wired APs do a really good job when carefully configured. The difficulty is that devices tend to connect to whichever AP that "replies" fastest. Which might not necessarily be the one with the best signal strength. Mesh does a better job of making sure you're always on the node with the best signal and throughput.
goldenfibre
Seasoned Pro
Fixes: 12
Re: Latest on FTTP?
@Gandalf
With this site metion of Plusnet Hub Two router will it free upgraded from Hub One to Hub Two for my parents FTTC?
Hub Two - thinking it could be for full fibre customers only! https://www.plus.net/help/broadband/router-information/
RRM
Re: Latest on FTTP?
Not going to mater to me now, spoke to the engineers in our area, there’s a blockage underground and Openreach #openreach aren’t doing anything about it. No work plans received so could be months before I see FTTP in our area if at all now
Extremely disappointed. #uselessopenreach.
R
