LAN not green
FIXEDTopic Options
- Full Fibre
- LAN not green
04-08-2023 3:25 PM
Just had an installation for full fibre, however was not delivered an ethernet cable for the engineer to test... Bought one cat5e, plugged in but LAN still shows as not green on the white box. Does it take a few hours to activate?
Fixed! Go to the fix.
Message 1 of 3
(1,164 Views)
2 REPLIES 2
Re: LAN not green
04-08-2023 3:44 PM
@craigy1 there's a cable supplied with the router ( Hub 2 ) ?
What router are you using and how is it connected to the white box (ONT) ?
Message 2 of 3
(1,151 Views)
04-08-2023 4:11 PM
All good now 😃 4pm it seemed to have corrected itself... Green light all on. Thanks anyway 👍
Message 3 of 3
(1,127 Views)
