LAN not green
craigy1
LAN not green
Just had an installation for full fibre, however was not delivered an ethernet cable for the engineer to test... Bought one cat5e, plugged in but LAN still shows as not green on the white box. Does it take a few hours to activate?
2 REPLIES 2
Fixes: 524
Re: LAN not green
@craigy1 there's a cable supplied with the router ( Hub 2 ) ?
What router are you using and how is it connected to the white box (ONT) ?
craigy1
Re: LAN not green
All good now 😃 4pm it seemed to have corrected itself... Green light all on. Thanks anyway 👍
