Just moved from Vodafone - disappointed
Ripshod
Don't get me wrong, the speed (900/100) is great. But that's about all.
I'm using my RT-BE88U, which served me well with vodafone.
My little list to work through:
1. Ping has shot up from 4 to 14ms
2. Can't ping my router from the internet - was told that would work.
3. No IPv6 - I was told this was easy to set up but now I find it's not even available.
4. Can't use my home VPN to access my servers at home. I'm totally blocked in. Was told Plusnet don't block ports.
5. DDNS (no-ip) doesn't work.
I'm thinking of cancelling, any reason not to?
15 REPLIES 15
Fixes: 558
Re: Just moved from Vodafone - disappointed
@Ripshod
That shouldnt be a problem as long as your router will accept ping from WAN. I use the thinkbroadband BQM which pings my router
Where did you get the info that it was easy to setup. It isnt currently available , it will be in the near future...
Correct, PLusnet dont block ports. Some older accounts have a 'Broadband firewall' option which can be used to block ports. Recent accounts dont have that facility, so no ports are blocked. I use a Wireguard VPN to access my network remotely
Fixes: 357
Yes - you would be hit with massive ETC's
Fixes: 105
@Ripshod
Although IPv6 is not yet available, PN are running a trial to get things sorted behind the scenes.
You can find the latest update in post #162 (page 11) here
https://community.plus.net/t5/IPv6-Trial/IPv6-Trial-Update/td-p/2006834
Ripshod
No cooling off period?
[/RANT]
Most of my problems solved though.
Strangely my built-in DDNS client won't update the noip servers.
I can't use wireguard to access my home network. OpenVPN is fine though.
Ping is now working, TBB updating again.
Only thing now is to get tunnelbroker working again (been a while)
Fixes: 357
The cooling off period starts from acceptance of your order, not the start of service.
Ripshod
That's a downer.
Kinda decides it for me. I'm getting the service back to just about what it was. No rush, I'll iron out the wireguard and tunnelbroker stuff over the next few days.
Native IPv6? I can live without it, I was with vodafone and on their forums for the failures and the final birth of their dual stack implementation. Like, reliving the past Cheesy
Thanks to everyone who responded.
Tags (1)
markhawkin
Aspiring Champion
Fixes: 20
Best guess about Wireguard is that something about the configuration uses the previous Vodafone configuration.
If you set up a new connection from scratch it will be fine.
With ping I guess there will be peering differences between Vodafone and Plusnet (BT).
I find 8.8.8.8 is 3ms
I believe Vodafone has quite a lot of regional peering wich may explain the observed differences.
Ripshod
This wireguard issue is the only thing that's currently giving me a headache. I've built a new profile and added it to my phone - all I get is handshake timeouts. Correct port (51820) and IP via noip.
I can connect fine over the local network but get the timeouts over WAN. I've checked the port isn't forwarded for other purposes. The port is correct, just no go. Even tried the MTU (went down to 1280) but that makes no difference. I can use OpenVPN and get access to my servers at home but it doesn't give access to my router.
Puzzling 🤔
Fixes: 558
That sounds like a firewall configuration issue on the router. Its not a general Plusnet problem, I use wireguard.
markhawkin
Aspiring Champion
Fixes: 20
@Ripshod
What is terminating the WireGuard session?
It sounds like you have the Plusnet Hub port forwading to something running Wireguard.
Fixes: 558
@markhawkin I'm assuming its directly on th RT-BE88U , its capable of being configured with a Wireguard server
Fixes: 139
@Ripshod
has the ddns caught up with your plusnet/bt public IP Address change?
Ripshod
@Dan_the_Van as I stated earlier:
"Correct port (51820) and IP via noip"
I've come to the conclusion the only reason wireguard was working on vodafone was that it had fully implemented IPv6 - perhaps if i'd used ipv4 only it would not have worked there either. I have tunnelbroker setup and working. Gong to export another config later and give it a final go.
Ripshod
To close this thread I'll just say that enabling IPv6 did the trick. I now have wireguard connecting again and full access to the router and my servers, and internet connectivity with pi-hole filtering the ads.
Happy bunny, but one who's waiting for proper dual-stack. 😎
