Just had it installed as of 27th
Ste-G-
Not sure on this and could be looking at it wrong but.
So I ordered 900mb Package.
But the router only seems to be syncing at 500mb (yes this is the guaranteed speed)
But I thinking I've been put on the 500MB package by Openreach/plusnet in error, as all I'm getting is the download speed of 250mb wireless or wired, which I believe is the guaranteed speed of 500mb?
Could this be the case or I'm I supposed to wait for the speeds to get better over a period of time?
7 REPLIES 7
DJMcKenzie87
Re: Just had it installed as of 27th
It appears that a common point of confusion for many individuals is the distinction between Wi-Fi speeds and broadband speeds, a observation I've frequently encountered in various discussions over time.
As of April 24th2026, I am now utilizing Sky Broadband, which offers full support for IPv6 addressing. Broadband Status page https://stats.uptimerobot.com/i06TwWNbhx
https://gaytxtbudzuk.co.uk/ my website
Ste-G-
This was a test in my routers software, not via wifi.
Your answer doesn't really help either
Fixes: 558
What make & model router are you using ?
Ste-G-
TUF-AX3000 V2
pjmarsh
Fixes: 24
A quick google of that and it sounds like a common complaint about the adaptive QOS can't handle the speeds, and disabling it (Adaptive QoS > QoS) usually fixes it.
Ste-G-
Thank you!! That was the problem for the full speed connecting to the router, but I'm still getting the same problem with speed going to devices
Fixes: 558
Are those connections wired or wireless ?
