Internet connection keeps dropping.
m7ck
I have just recently (4 weeks ago) switched to plusnet from sky and am already regretting it. At least a dozen times a day the internet drops connection, happens to several different devices, sky a box, phones, iPads, security system. This is getting ridiculous how do I go about getting it fixed.
16 REPLIES 16
Fixes: 378
Re: Internet connection keeps dropping.
@m7ck Welcome to the forums. This could be because your connection did not automatically authenticate with the correct details. Check that the user name on the hubs 'Troubleshooter' page matches your user name and is not displaying '[email protected]'.
m7ck
Thanks for reply but it is my username that is listed and not setup.
Fixes: 378
OK - it was just a thought, because it has happened to quite a few new(ish) customers recently.
Can you post that page - obscuring your username, please?
Is your telephone line quiet - dial 17070 option 2. After the confirmation of your phone number, there should be no sound other than the regular 'Quiet Line Test' message. If there is, report a phone fault.
m7ck
I have no idea about the phone line. I don’t have a landline phone.
however I had no issues at all with sky.
Fixes: 378
That is a pity, because problems on the phone side of the installation can have massive effects on the broadband side. If you could post your Troubleshooter information page, though, it may give us a clue.
Sky could have been using their own equipment in the exchange - Plusnet use the BT infrastructure.
m7ck
Apologies for my ignorance, but what do you mean by troubleshooting page? You mean hub manager home?
Fixes: 378
Sorry, this picture may help:-
If you click the Troubleshooting tab - top right and then the Helpdesk below it should open the required page.
m7ck
thankyou, does this help?
Fixes: 378
It does, thank you.
Two things stand out to me there (1) Your hub software could do with an update - further help on that to follow.  (2) Your downstream noise margin is too low, which will need PN staff intervention to remedy.
In the absence of the important phone test, can you post the detail from the Event Log tab on that page, please.
m7ck
Fixes: 378
Thanks for that. Unfortunately, apart from showing that the hub is doing its job blocking unsolicited traffic, it does not show any connection issues - could you post the same thing immediately following a disconnection?
Re: the software - I suggest you post on this topic https://community.plus.net/t5/My-Router/Hub-One-5GHz-WiFi-issue/m-p/1696363#M15510 , requesting an upgrade to the .289 version.
Hopefully, when PN pick this up, they will post a RADIUS graph and the results of a KBD test, along with suggestions on a resolution.
Fixes: 146
Hi @jab1
When viewing the log file if you change the category to WAN you can see when the last  PPPoE connection was last established and dropped
also another thought splitting the 2.4 and 5 GHz wifi sync might help.
@m7ck Do you notice if the front light on the Hub One change from Blue at all?
Dan
Fixes: 378
@Dan_the_Van Sorry, it isn't my log, and I have never used either of the hub variants, so I was not aware of that - thanks for the information.
If @m7ck gets the .289 release, I understand that niggle  with regard to the bans is resolved - but I can't confirm.
LaurenB
Fixes: 131
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 65.4 Mbps
Upstream Speed 8.3 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Voice fault suspected - contact Voice CP to progress copper issue
Cross Talk Not Detected
Estimated Line Length In Metres 816.6
Upstream Rate Assessment Good
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
DP Type Internal
Profile Name 0.128M-80M Downstream 4dB, Retransmission High - 0.128M-20M Upstream, Retransmission Low
Time Stamp 2021-09-12T19:45:00
Parameters MIN MAX AVG
Down Stream Line Rate 64.7 Mbps 68.9 Mbps 66.7 Mbps
Up Stream Line Rate 7.8 Mbps 8.3 Mbps 8.2 Mbps
Up Time 754.0 Sec 900.0 Sec 899.3 Sec
Retrains 0.0 1.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2021-09-25T18:11:07Z 2021-09-25T18:26:07Z
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
 Lauren Barry
