How does it work?
- Full Fibre
- Re: How does it work?
How does it work?
Thursday
What doI need to do? Do I need to book an engineer?
Thursday
Have a look at the following (use the Address version if no phone).
What does it say below the results window about the Full Fibre install.
Thursday
@DonnaLalek If there is an ONT it will be inside the house see Openreach ONT
Normally when you order Plusnet would check the ONT is there (as long as it is powered on)... there may also be a grey CSP box on the outside of your house (but not always.
If you don't have an ONT already installed you will need an engineer to instal the fibre and ONT. This would normally be arranged when you order by your ISP (Plusnet.)
Thursday
Thursday
Thursday
What exactly does the Checker say about Full Fibre below the results window.
This tells you what equipment OR think you have. Answer this and we can advise on a course of action.
Thursday
Thursday
Can you post a an image of that page, as an attachment so we can interpret it, please? Obscure personal details.
Thursday
Thursday
If there is a 'paper clip' image below the reply window, click it and follow the prompts.
Thursday
@DonnaLalek wrote:
It says there is a ONT with no spare ports so a new one may be ordered
Thanks - this is what I was looking for.
It confirms OR think you have an ONT installed. Is it power up with lights visible?
Thursday
Thursday
Thursday
OK, if you are using a mobile device, select the 'desktop' version of the site.
As @bmc says though, it appears you have an ONT installed.
Thursday
