Full fibre lag
Meatballs_100
Full fibre lag
HI - we have had 500mb FF for a few weeks. To start with all was well. fast speeds and TV reception good. Now everything is laggy and slow. Have done three speed tests - This does not look like what we had originally. this is what I now get.  any tips please?Screenshot 2026-04-26 at 16.59.15.pngScreenshot 2026-04-26 at 16.58.39.png
6 REPLIES 6
Fixes: 558
Re: Full fibre lag
Are you doing those tests over a wireless or wired connection ?
Meatballs_100
Re: Full fibre lag
wireless but have nothing streaming. all the speed tests I've done have been wireless and better before
Fixes: 558
Re: Full fibre lag
Only wired tests can give a definitive answer but Check that your device is connected to the 5ghz WiFi band. . Those speeds are typical for a device connected to the 2.4ghz band
Meatballs_100
Re: Full fibre lag
ok just rechecked on ip address. I had switched 5ghz off to try to sort the wifi on the oven. I had clicked but clearly hadn't saved the changes. rookie error.
Longliner
All Star
Fixes: 8
Re: Full fibre lag
If it's an AEG oven I wouldn't bother with the wifi. We replaced our old Bosch oven with AEG a few months back and it insisted on resetting itself two or three times before it would work. We had the AEG tech out twice, he said it was normal while the oven sought wifi connection even though it was deselected, AEG confirmed this in writing, we rejected the oven until the store manager fitted a new one and it worked as well as it's supposed to work, ie fiddly to operate, insists on closed door to grill so you can't see your sausages burning, etc. My wife and I agree it's the worst buy we ever made, as is our new AEG microwave, and we wish we had kept our old Bosch appliances and refitted them. Does anyone use wifi on their oven, or is it a gimmick like the new toothbrush which is claimed to have AI?
Meatballs_100
Re: Full fibre lag
Yes I use it all the time. I can set it remotely also it talks to my Apple Watch so it tells me when preheat is done, when time is up and I can switch oven off from my watch or phone.
