Full fibre - Steady Orange light No connection. Bt fibre hub green
- Full Fibre
- Re: Full fibre - Steady Orange light No connection...
30-11-2024 11:16 AM
Followed all troubleshooting and changing @plusdsl.net. I’ve had 5 Openreach engineers in my property - I’ve installed a new router.
Openreach blaming plusnet - plusnet blaming openreach. Unable to go any longer with no services for work next week having detrimental effect on health within property. Explained this and told another engineer will attend Monday.
Openreach engineer claims it’s something to do with settings.
Hoping someone can help me - full connection coming in just not making it to router.
Re: Full fibre - Steady Orange light No connection. Bt fibre hub green
30-11-2024 11:34 AM
@Ashbash1982 Did you previously have an FTTC connection with PN? The OpenReach side sounds perfectly good to me, so the only two obvious culprits can be PN, or something at your end.
30-11-2024 12:20 PM
30-11-2024 12:34 PM
If PN have an open fault with OR, then unfortunately you (and they) are at the mercy of that unaccountable organisation. I don't know what that fault code is either, but it does suggest the fault is somewhere in the OR network if it is reported after a kbd check.
30-11-2024 12:45 PM
30-11-2024 12:51 PM
To eliminate the unlikely possibility that the router is the cause of your problem, if you have an Ethernet connectable computer, connect it directly to the ONT and set up a temporary PPPoE connection using your PN credentials.
30-11-2024 1:23 PM
I don't know what the fault means but it appears PN need to raise a fault with OR after receiving it. See
30-11-2024 1:33 PM - edited 30-11-2024 1:33 PM
@bmc Thanks for that link - just one observation - it, according to the 'overview' it is for 21CN copper and fibre broadband, Haven't read it fully, but does it cover FTTP, which is a totally different technology?
30-11-2024 1:48 PM
It appears to be for both copper and fibre.
1. To run KBD on 20CN product select 20C Knowledge Based Diagnostics
2. To run KBD on 21CN Copper and Fibre Product select New Knowledge Based Diagnostics
30-11-2024 1:51 PM - edited 30-11-2024 2:00 PM
@bmc Fair enough, although it is a 2022 publication, so how up to date is it? I'll see if I have time to examine it a little more closely later.
That PDF is an 'idiots guide' to CP's for raising fault - totally useless for anything else.
30-11-2024 2:56 PM
Agreed it is an idiots guide but it at least gives us mere mortals an idea of what happens.
Further research gives this from 2014.
In particular
Given the OP stated the fault code was 509 this appears to fall under the No Fault heading.
30-11-2024 3:04 PM
Thanks for the further info, @bmc . So, if there is 'no fault', why are OR sending out a 'senior engineer' next week?
30-11-2024 3:28 PM
But whose settings? Has it ever worked?
When my full fibre was installed the ONT lights were correct but there was no service, which the installation technician put down to an Openreach routing problem. This was fixed after a telephone conversation between the tech and, presumably, Openreach.
30-11-2024 4:00 PM - edited 30-11-2024 4:01 PM
If the PLUSNET HUB TWO router as configured worked with FTTC, upon switching to FTTP, it will work correctly when ethernet port 4 is connected to the ONT.
If the ONT has no red lights, then this is most probably a BTW / BTOR configuration issue similar to that seen around here before.
We have though seen deep technical oddities with third party routers which work fine on FTTC but not on FTTP.
30-11-2024 4:06 PM
- Full Fibre
