Full fibre - Steady Orange light No connection. Bt fibre hub green
Ashbash1982
I had full fibre installed and been left with no service for 7 days. Disabled and unable to work from home. LAN - Green PON - Green Router steady orange.
Followed all troubleshooting and changing @plusdsl.net. I’ve had 5 Openreach engineers in my property - I’ve installed a new router.
Openreach blaming plusnet - plusnet blaming openreach. Unable to go any longer with no services for work next week having detrimental effect on health within property. Explained this and told another engineer will attend Monday.
Openreach engineer claims it’s something to do with settings.
Hoping someone can help me - full connection coming in just not making it to router.
44 REPLIES 44
Legend
Fixes: 289
Re: Full fibre - Steady Orange light No connection. Bt fibre hub green
@Ashbash1982 Did you previously have an FTTC connection with PN? The OpenReach side sounds perfectly good to me, so the only two obvious culprits can be PN, or something at your end.
Ashbash1982
Hey thanks for replying I’m not that technical either so I’ve went into advanced settings and did what I could see from comments. I’m now back to @plusdsl.net all entered in and back to default settings. Bt openreach keep saying it’s an issue with router and plusnet keep saying they have fault on openreach on kbd report outcome code 509 fault detected in network. I’m still trying to work out what that means lol
Legend
Fixes: 289
If PN have an open fault with OR, then unfortunately you (and they) are at the mercy of that unaccountable organisation. I don't know what that fault code is either, but it does suggest the fault is somewhere in the OR network if it is reported after a kbd check.
Ashbash1982
Thanks - I’m waiting on senior engineer who’s coming out on Monday. 5 engineers external and internal in and out all week, also new router. Don’t understand why they don’t have a work around with the router settings after people switch or even a grace period changing lines over. Tried everything with the settings. Gutted because I will need connection asap and really didn’t want to go to another supplier away from openreach pole. But kind of no choice if no solution by next week. Plusnet manager was useless so gives me no confidence on it being sorted.
RobPN
Fixes: 13
@Ashbash1982
To eliminate the unlikely possibility that the router is the cause of your problem, if you have an Ethernet connectable computer, connect it directly to the ONT and set up a temporary PPPoE connection using your PN credentials.
Fixes: 60
@Ashbash1982
I don't know what the fault means but it appears PN need to raise a fault with OR after receiving it. See
https://www.btwholesale.com/assets/documents/help-and-support/broadband/broadband-repair-guides/rais...
Legend
Fixes: 289
@bmc Thanks for that link - just one observation - it, according to the 'overview' it is for 21CN copper and fibre broadband, Haven't read it fully, but does it cover FTTP, which is a totally different technology?
Fixes: 60
@jab1
It appears to be for both copper and fibre.
1. To run KBD on 20CN product select 20C Knowledge Based Diagnostics
2. To run KBD on 21CN Copper and Fibre Product select New Knowledge Based Diagnostics
Legend
Fixes: 289
@bmc Fair enough, although it is a 2022 publication, so how up to date is it? I'll see if I have time to examine it a little more closely later.
That PDF is an 'idiots guide' to CP's for raising fault - totally useless for anything else.
Fixes: 60
@jab1
Agreed it is an idiots guide but it at least gives us mere mortals an idea of what happens.
Further research gives this from 2014.
https://my.btwholesale.com/assets/documents/knowledge_based_diagnostics/NKBD_Customer_Best_Practice_...
In particular
Given the OP stated the fault code was 509 this appears to fall under the No Fault heading.
Legend
Fixes: 289
Thanks for the further info, @bmc . So, if there is 'no fault', why are OR  sending out a 'senior engineer' next week?
Fixes: 430
But whose settings? Has it ever worked?
When my full fibre was installed the ONT lights were correct but there was no service, which the installation technician put down to an Openreach routing problem. This was fixed after a telephone conversation between the tech and, presumably, Openreach.
Fixes: 175
If the PLUSNET HUB TWO router as configured worked with FTTC, upon switching to FTTP, it will work correctly when ethernet port 4 is connected to the ONT.
If the ONT has no red lights, then this is most probably a BTW / BTOR configuration issue similar to that seen around here before.
We have though seen deep technical oddities with third party routers which work fine on FTTC but not on FTTP.
ellie24
We’re having the exact same issue. Was installed on the 22nd. Steady orange light, green lights on the wall. No one is giving us answers. We’ve been told it’s a PPP issue that should resolve itself. But honestly we are loosing hope now. We’ve got two children one disabled who relies on the WiFi, I need to do work from home also. Anyone else with this problem?
