Full Fibre 900 speed lower than expected
grumble
Re: Full Fibre 900 speed lower than expected
I'm on a BT fibre connection. I used the BT speed tester. I think the Hub2 also uses that.
Fixes: 334
Still not totally with you. I'm not with a BT group company, although my ISP uses their network, but I don't use their speed test - as the Hub2 doesn't, as it doesn't do speed tests, but I get the results I expect.
Fixes: 1,491
The BT speedtest for full fibre isn't great, you're much better off using Speedtest.net
