Full Fibre 900 speed lower than expected
- Full Fibre
- Re: Full Fibre 900 speed lower than expected
- « Previous
- Next »
10-01-2025 8:55 PM
I'm on a BT fibre connection. I used the BT speed tester. I think the Hub2 also uses that.
Message 31 of 33
(578 Views)
10-01-2025 9:03 PM
Still not totally with you. I'm not with a BT group company, although my ISP uses their network, but I don't use their speed test - as the Hub2 doesn't, as it doesn't do speed tests, but I get the results I expect.
11-01-2025 4:00 PM
The BT speedtest for full fibre isn't great, you're much better off using Speedtest.net
Message 33 of 33
(501 Views)
- « Previous
- Next »
- Full Fibre
