Full Fibre 145 Speed not as stated
FIXED- Subscribe to RSS Feed
- Full Fibre
- Re: Full Fibre 145 Speed not as stated
a week ago
This hasn't happened and I have tried other fixes found on the forum but all to no avail.
Any suggestions warmly received.
Fixed! Go to the fix.
a week ago
@Slunnyboy can you inspect the connections on the WAN port for damage ? Compare it with one of the LAN ports
a week ago
Until I upgraded I have never touched the Wan port since first getting the Plusnet Hub 2 several years ago.
a week ago - last edited a week ago
Well it's either a cable, a wan port or an ONT fault..
Try connecting the ONT to a LAN port and check the hub 2 log to see what connection speed is reported. That should confirm if it's a wan port fault or not.
We've had a recent instance of a router with a similar fault. Does your router serial no start with an 'R' ?
Have a look at this thread https://community.plus.net/t5/Full-Fibre/Port-2-speed-limitation-need-service-moved-to-port-1-but-bl...
Ignore the bit about the port 2 of the ONT it was a red herring
20:11:44, 26 Apr.Wire Lan Port 3 up, Speed 1000 Mbps
As you can see the speed was 1000Mbps when I switched ports which indicates a problem with the Hubs WAN port I presume?
Serial number of Hub doesn't start with an R
a week ago
Correct. Call support in the morning and explain. They should send a replacement router.
Post back if you have difficulty getting a repaacement
a week ago
Phone is normally the only way to contact support but I'll try tagging the help team to see if they can assist in the circumstances
@Katie_B is it possible for someone to assist here ?
a week ago
a week ago
@Slunnyboy - I've arranged for a replacement hub to be shipped to you. All being well, it will arrive in the post tomorrow.
a week ago
- last edited
a week ago
by
That's fantastic, thank you very much indeed.
Best wishes, <Removed>
Personal information removed from a public forum (to an area that staff can see).
a week ago
a week ago
Thanks for letting us know
- Full Fibre
