Fibre to the Premises - FTTP Trial
- Full Fibre
- Fibre to the Premises - FTTP Trial
Re: Fibre to the Premises - FTTP Trial
16-12-2010 11:37 AM
When I get on FTTP will I need a new router? It so can I have a Netgear WNR3500 one also as I need maximum WiFi range?
Cheers
16-12-2010 12:38 PM
I have replied your questions.
Looking forward...
thanks,
Maneesh
16-12-2010 3:20 PM
Before:
After:
16-12-2010 11:06 PM
Awesome, you must be pleased?!
Quote from: mudstuff Had my install today and went without a hitch, even kindly squeezed the optical down my exisiting conduit (first floor lounge) to save tacking the cable up the outside of the house.
What's the latency like now?
Paul
17-12-2010 9:29 AM
Quote from: cooperlegend Can I double check that I am on your FTTP list, user name is cooperlegend7
Hi John,
Welcome to the forum and welcome to Plusnet, I've sent you an invite ticket out to the trial, same as my reply to Anne and Maneesh above if you can reply back to the ticket I'll get things moving for you.
Plusnet Technology
17-12-2010 9:29 AM
Excellent! And finally too! Welcome to the club
Plusnet Technology
17-12-2010 10:04 AM
Quote from: dave
Hi John,
Excellent
Have replied to the ticket, any day is fine with me
17-12-2010 2:12 PM
My ping is around 10ms, a good improvement on the 30ms+ (sometimes upto 100 or so) I had before.
@ Dave
Cheers Dave, got there in the end.
Look forward to trying out some black ops on it over the weekend
20-12-2010 5:01 PM
My exchange has just been enabled. Please could I be put on the FTTP trial - Ticket #37313161 ?
Many thanks.
20-12-2010 7:35 PM
We'll update your ticket as soon as we get your order placed
21-12-2010 5:52 PM
I just read the post about the "build" being finished. Does this mean I'm doomed, even though I saw Openreach laying what I assumed to be cable a month or so ago?
MK14 5DZ
Chris
22-12-2010 12:54 PM
My data shows you're on cab 39 which hasn't been included in the trial area unfortunately. I've not heard about any changes to the trial area so may the Openreach people you saw may not have been doing FTTP. There's a possibility they will review the missed areas to see if they can do FTTC but it's not likely for a while.
Plusnet Technology
23-12-2010 1:56 PM
Quote from: dave It's on the way and should be with you in the next couple of days. Setup guide is here:
http://www.dtomlinson.plus.com/fibre/fttp_guide_netgear.doc
Hi Dave
Arrived today, thank you! Took 10 minutes to set-up and is working great. I'll post in a week or so on if the wifi issues have gone away.
I have the Thomson all boxed up in the original packaging. Do you want it back?
David
03-01-2011 9:56 PM
Re: http://community.plus.net/forum/index.php/topic,83633.msg764240.html#msg764240 ; That fits in with what I have seen. Any current IP sessions, e.g. ssh don't drop, and if I VPN in to the office, I can then access everything. I've updated the DNS settings on the router as suggested, and will let you know how it goes. At moment, pre dns update, the connection is defaulting to the BT service page, 20-30 times a day, so fingers crossed.....
Julian
04-01-2011 3:11 PM
Just for info, we are on the FTTP trial and we also were seeing the BT Service Page a lot. Having modified the DNS settings the problem went away but this is just fixing the symptoms rather than the problem, which is at BT's end.
Other than that we're really pleased so far
- Full Fibre
