FTTP (trial) recent connection drops (Bradwell Abbey)
- Full Fibre
- FTTP (trial) recent connection drops (Bradwell Abb...
12-07-2015 2:35 PM
The last one was about 25 mins ago and have just reconnected so posting this straight away.
Powering off the BT Openreach modem for 20 mins seems to solve them mostly.
On the hottest day of the year, experienced a red LED on the BT modem at the LOS position, and this connection drop lasted several hours.
I was concerned that when I got through to Plusnet customer services (online chat) they told me they would not raise a ticket for me as they do not consider trials as part of normal service! Someone at Plusnet please confirm that this is not the case!?
Re: FTTP (trial) recent connection drops (Bradwell Abbey)
13-07-2015 9:55 AM
<img src="http://community.plus.net/visualradius/generated/image14367772928110.png"/>
I see a few cut outs here. However, a bit of consistency other than yesterday afternoon. Are you ok to keep monitoring for now, and if these cut outs increase, are you ok to let me know?
Matty
13-07-2015 11:08 AM
16-07-2015 5:40 PM
Quote from: MattyC I see a few cut outs here. However, a bit of consistency other than yesterday afternoon. Are you ok to keep monitoring for now, and if these cut outs increase, are you ok to let me know?
Just had another connection drop, starting around 1648 hrs today, with a red LED on the BT modem at the LOS position.
16-07-2015 7:28 PM
Currently having a connection drop, started around 1903 hrs today, with a red LED on the BT modem at the LOS position.
23-08-2015 9:34 AM
23-08-2015 10:45 AM
This is still a problem now, even after powering off the BT openreach modem for 20 mins.
23-08-2015 11:20 AM
23-08-2015 3:40 PM
I don't suppose this helps you very much, but it does show that it is not the whole of Bradwell Abbey.
Good luck.
Peter
23-08-2015 10:42 PM
Yes I had had a stable connection for a long time prior to July 2015, too. I am guessing my connection is through a card at the local exchange which has developed a fault - possibly a tendency to overheat.
- Full Fibre
