Fibre to the Premises - FTTP Trial
- Full Fibre
- Fibre to the Premises - FTTP Trial
Re: Fibre to the Premises - FTTP Trial
10-12-2010 12:40 PM
Quote from: youngsyp Check the mainsite, under the "Help & Support" tab.
Quote from: OllieGBR Where do I find this message you refer to?
Many thanks
Paul
Thanks Paul, however there is nothing there
10-12-2010 12:45 PM
10-12-2010 2:14 PM
10-12-2010 2:33 PM
vyelland - thanks, Highams Park is now due next month so I'll check your area once it starts going and be in touch.
ekw and jwhosborne - I've seen a couple of similar problems on FTTC, your connections don't seem to be dropping out so I think that at some point the connection dropped and the router/PC cached a BT DNS server. If you try specifying the DNS servers as 212.159.6.9 and 212.159.6.10 hopefully that should fix it. It seems to have for the FTTC customers seeing it.
bc - brilliant! That's got to be one of the quickest installs.
Plusnet Technology
10-12-2010 2:37 PM
10-12-2010 2:51 PM
10-12-2010 4:55 PM
Awesome, thanks.
Quote from: bc Pinging bbc.co.uk gives a result of 5ms
Pingtest gives these results;
I was lucky enough that my old IDNET connection, whilst slow, was very stable and ping was usually very good.
My current ping time is around 21ms to the BBC and around 23ms (with 1ms of jitter) to the Milton Keynes server, through Pingtest.net. Hopefully, that should drop consideranbly with an FTTP service.
Paul
10-12-2010 8:57 PM
Quote from: dave OllieGBR - check again, I've resent it as it had timed out
Done, thanks Dave
12-12-2010 5:09 PM
Quote from: Knavesdied Hi Dave
I'm having problems that sound similar to Gary with the TG789vn. Connections wifi dropping from some devices but not on others (seemingly regardless of manufacturer or range from the router), router sometimes not issuing DHCP IP address to my Squeezeboxes, and generally things feeling slower than when on the copper!!
Quote from: dave readingg and jonnywishbone I'll send you both a Netgear, see if that helps, the setup guide is here:
http://www.dtomlinson.plus.com/fibre/fttp_guide_netgear.doc
Hi Dave
Back in October, I reported similar problems with wifi connectivity and the Thomson TG789vn as readingg and jonnywishbone. Unfortunately they're still going on. Wired connectings are fine, but I've tried every combination of wifi settings under the sun on the Thomson with no improvement. After a restart the speed over wifi is fine for a while and then drops to virtually zero. Here's an example pair of results from Speedtest.net before and after a reset of the router:
Date,ConnType,Download,Upload,Latency,ServerName
2010-12-10 23:19,Wifi,4624,14333,172,"Milton Keynes"
2010-12-10 23:08,"reset router"
2010-12-10 23:07,Wifi,444,2,612,"Milton Keynes"
Any chance I can give the Netgear WNR3500 a try?
Many thanks
David
13-12-2010 12:13 PM
13-12-2010 3:47 PM
I have placed an order today with plusnet.
can you please add me to the fibre trial?
my id is maneeshks and postcode is mk58er?
it seems many people have trouble with thomson modem, is it possible for you to arrange to send me a netgear one as part of my order?
thanks,
Maneesh
14-12-2010 6:23 PM
I've just jumped ship to join the Plusnet family and would like to request to join the FTTP trial on the Bradwell Abbey exchange.
My plusnet username is acrowter.
Anne
16-12-2010 10:16 AM
Quote from: Knavesdied Any chance I can give the Netgear WNR3500 a try?
It's on the way and should be with you in the next couple of days. Setup guide is here:
Plusnet Technology
16-12-2010 10:22 AM
I've sent you both an invite ticket out which you can view here:
https://portal.plus.net/my.html?action=questions
If you can reply back to the ticket by adding a comment with the answers to the questions at the bottom I'll add you both to the trial. Please note that the earliest appointments are now around 7th January.
Plusnet Technology
16-12-2010 11:31 AM
Can I double check that I am on your FTTP list, user name is cooperlegend7
Many thanks
- Full Fibre
