Fibre drops connection same time each day
SaintG3
My fibre worked perfectly for two months but for the last 10 days stops working between 20.00 - 21.00 for around 2 hrs. Anyone else have this problem? Any idea what it can be?
5 REPLIES 5
Fixes: 378
Re: Fibre drops connection same time each day
That sounds strange for a FF connection, @SaintG3 . Any clues in the event log? Do any of the lights on either the Hub or the ONT  change at the time?
SaintG3
Hi, the ONT goes red in the middle light,
Fixes: 378
Solid or flashing? In either case, this is a problem in the fibre network which you need to refer back to Openreach via Plusnet.
SaintG3
Solid red light. Openreach have come out but it work ok through the day only at night it drops at the times mentioned they can’t find ant faults
Fixes: 378
Go back to PN and ask them to get OR to check again - they (OR) should be able to check the network logs.
