Fibre dropout
lone
Fibre dropout
Hello,
I've been seeing some dropouts on my connection since we had it 'uncapped' in mid December. Last night after it dropped it returned at around 6mb. A power cycle fixed this, but it has now happened again. The connection was relatively stable before this, and my configuration has not changed. Picking up the phone it seems there is heavy crackling on the line (the line is never otherwise in use). Speedtest and stats are attached.
Could someone please look into this?
Thanks.
5 REPLIES 5
Fixes: 251
Re: Fibre dropout
If there is noise on the line, broadband is not going to work properly at all.  Please raise a phone line fault using the link below.
lone
Re: Fibre dropout
Thanks Townman. A phone line fault was found and an engineer visit has been arranged on Monday.
Staff, if you require further details please let me know. Otherwise, there is not much to add until then.
Fixes: 1,663
Re: Fibre dropout
Thanks for your post @lone
I'm sorry to see you're having connection issues.
Let us know how the engineer visit goes.
lone
Re: Fibre dropout
Hello,
The engineer has now left, after repairing some damage outside. At a quick glance, the connection seems to be fine again.
Can I ask if my speed was throttled or impacted by all this, and if so could we have that reset?
LaurenB
Fixes: 131
Re: Fibre dropout
Hiya @lone, thanks for getting back to us with the update. I am pleased things seem good so far since the work.
I have tested the line and can see the current sync speed is 52mb and doesn't look to have been banded in anyway.
Let us know how things go!
 Lauren Barry
