Fiber Install Complete
khaled35
Great experience. Engineer showed up when they said he would. He banged on with the work and was done in about 3 hours. Tested connection and confirmed working.
How long after an install should I see an increase in speed? I'm moving from 74FTTC to 300FTTP.
20 REPLIES 20
Fixes: 480
Re: Fiber Install Complete
@khaled35
You should get a text from Plusnet when they have set up their end. It should be by midnight.
Have you tried the new connection to see if it's yet working?
Fixes: 586
There is no stabilisation period on FTTP. Once your account change has completed (sometime later today) then the speed should change. Login to your account and check if your product and current line speed have changed. Once they have, reboot the router and you should be good to go...
khaled35
Thanks. Thought there might be a after midnight thing.
Yes, connection is working and am getting 75down and around 50up.
khaled35
Product still indicates the old one. Not sure how to check line speed on the account, but not important. I'll wake up tomorrow morning and come down the stairs like it's Christmas.
Fixes: 480
@khaled35
Fingers crossed! If it doesn't pick up try the reboot suggested by @MisterW
Fixes: 586
login and then go to the Broadband tab , it should show the product and current line speed , which should show 300 Mb once the product change is complete
khaled35
Here's what I see
Think product hasn't changed yet.
Fixes: 586
Yes, the product change hasn't completed yet. It should complete later today, keep checking occasionally and once it shows Full fibre, then reboot the router.
khaled35
Got the email about product change being complete. I checked the site and yes, it's changed there too
Do a speed test and I max out at 94. This is a wired connection.
Fixes: 480
@khaled35
Check out your Ethernet cables, they need to be at least CAT5e and also check the speed of your Ethernet adapters. It sounds like something is only running at 100MBps.
Are you using a Hub 2? Have you logged in to your router and seen what data speed it is reporting?
Fixes: 586
That sounds like you've got an ethernet connection somewhere that's only 100Mb capable.
Are all your cables cat5e or better ?
Is ther NIC  on the testing machine gigabit capable ?
Are you using the Plusnet hub 2 router or your own ?
khaled35
You guys may be on to something. On wireless, I get 277Mb
I think it might be the ethernet cable from ONT to the router. The one provided was too short, and I just had this really long and old one laying about. I'll need to buy one that's an appropriate length.
What category cable is ideal?
RealAleMadrid
Fixes: 68
@khaled35  Cat5e is perfectly good enough, a CAT6 cable will not make the connection any faster.
Fixes: 480
@khaled35
If you’re getting 277Mbps over wireless it won’t be the ONT to router cable
