FTTP Trial
bluey78
FTTP Trial
Hi got FTTP and have unlimited fibre extra .Was expecting speeds of up to 78 mb but getting around 40 mbs. Is this correct
24 REPLIES 24
grahamt
Re: FTTP Trial
Sounds odd, especially if you really do have FTTP as opposed to FTTC.
What's your upload speed? If it's as low as 2mb/s you may have been put on the wrong package.
HarryB
Fixes: 256
Re: FTTP Trial
Welcome to the community forums @bluey78
I've checked your connection and it's provisioned correctly on 80/20, however I've noticed that you've only recently changed from Unlimited Fibre to Unlimited Fibre Extra, and following this change but when you made this post, your connection had not dropped.
Since making this post, I see your connection has dropped and I'd expect you to now be seeing the higher speeds.
Are you still experiencing any problems with this?
 Harry Beesley
Nigel68
Re: FTTP Trial
Hi upload speed is 20mb
Nigel68
Re: FTTP Trial
Hi over weekend getting between 35 -49 mbs download speed
Nigel68
Re: FTTP Trial
Hi plusnet any news on my download speed . Was told with FTTP and unlimited extra would get 78 -80 mbs still getting only 40-50 Huh
MatthewWheeler
Fixes: 437
Re: FTTP Trial
There's no issues we can see.
Are you connected over a wired or wireless connection?
 Matthew Wheeler
Teece
Re: FTTP Trial
...and what router are you using?
Nigel68
Re: FTTP Trial
Wireless connection
jelv
Fixes: 10
Re: FTTP Trial
Run a test to see what speed you get wired.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Nigel68
Re: FTTP Trial
Only getting 32 mbs wired download on FTTP.. Huh Still not sorted and paying for unlimited fibre extra..not happy..
jelv
Fixes: 10
Re: FTTP Trial
Have you tried powering down both the Optical Network Termination box and router for a few minutes?
Nigel68
Re: FTTP Trial
Tried rebooting everything !!! Still only getting 40 mb download...
What next ?Huh
Nigel68
Re: FTTP Trial
Hi any more news on my restricted service ?
HarryB
Fixes: 256
Re: FTTP Trial
I'd recommend raising a fault over at http://faults.plus.net so we can get this matter raised with our suppliers for further investigation.
Let me know once you've done this and I'll get it picked up for you.
Thanks.
 Harry Beesley
