FTTP Trial
- Full Fibre
- Re: FTTP Trial
FTTP Trial
14-03-2016 10:52 PM
How do I go about signing up for the trial for FTTP?
Message 1 of 5
(1,382 Views)
4 REPLIES 4
Re: FTTP Trial
15-03-2016 8:57 AM
First, check with BT if you are able to get FTTP using the BT Broadband checker at http://www.dslchecker.bt.com/adsl/ADSLChecker.Telephone?URL=&SP_NAME=a%20service%20provider&VERSION=...
If the first line of the "Featured Products" says "WBC FTTP" then you can apply for the trial at http://trials.plus.net/
Another way is to go to the BT Retail website and see if you can buy Infinity 4 from them (FTTP at 330Mbps download). If you can then you can also apply to join the Plusnet trial or use BT or even Zen (the latter 2 offer FTTP as a product not just a trial)
Finally Plusnet only offer 2 speeds for FTTP, 40Mbps down/2Mbps up or 80Mbps down/20Mbps up. Use BT if you want faster.
Message 2 of 5
(904 Views)
Re: FTTP Trial
15-03-2016 4:31 PM
Thanks for the response, I should have clarified that I can get FTTP only, which was why I asked.
I'd be happy with 80Mbps tbh as right now I get 1Mbps...
Message 3 of 5
(904 Views)
Re: FTTP Trial
15-03-2016 4:34 PM
To proceed, we'd just need you to respond to the ticket with the relevant information ![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
Looks like a colleague responded to you earlier today on Ticket: 118489042
Message 4 of 5
(904 Views)
Re: FTTP Trial
15-03-2016 5:00 PM
@izzet
Glad you can and have been able to apply for the trial.
The reason that I stressed the "WBC FTTP" bit is that people see "FTTP On Demand" and assume that they can get FTTP. The On Demand variation is a very rare and expensive beast ,and no one seems even sure If BTW are accepting orders currently for said mythical creature.
Message 5 of 5
(904 Views)
