FTTC - still slow from new install on Friday
- Full Fibre
- FTTC - still slow from new install on Friday
31-01-2011 9:31 PM
Message 1 of 5
(1,250 Views)
4 REPLIES 4
Re: FTTC - still slow from new install on Friday
31-01-2011 9:34 PM
Your plusnet profile has probably not been set for FTTC yet (it needs to be set to 20Mbs). Did you try ringing support to get it changed?
Message 2 of 5
(370 Views)
01-02-2011 6:17 AM
That ping on your speedtest result seems to be extremely high for a 'local' server (for comparism mine is 11ms - 160+ is something I would usually expect to see for a mid/west coast US server).
Are you sure nothing else was using the connection when you did the test? A higher than expected ping rate can be indicative of something using the connection pretty heavily (usually something that fires off multiple connections).
Assuming the test was the only thing running I would suspect your exchange is congested or there is some other issue with the line.
Message 3 of 5
(370 Views)
01-02-2011 9:29 AM
Thanks - I phoned customer support there and they said my profile is fine and everything looks ok at their end.
I have to do a few more speed tests for them which I will do when I get home later and post them on my ticker.
As to the ping I am in Northern Ireland and wasn't doing anything else at the time so perhaps it was just a busy server. I have got up as high as 20mbs download on other tests but the engineer who did the install said I was testing at full speed so 8mbs last night was way below my expectations of FTTC.
Message 4 of 5
(370 Views)
01-02-2011 7:13 PM
Message 5 of 5
(370 Views)
- Full Fibre
