FTTC Expansion?
- Full Fibre
- Re: FTTC Expansion?
Re: FTTC Expansion?
06-07-2010 10:58 PM
Re: FTTC Expansion?
06-07-2010 11:41 PM
BT speedtester results show a max achievable speed of 43329 Kbps but the best effort download speed is only 23104 Kbps
Can you let me know what speed my PN profile has been raised to? As you mentioned previously the PN IP profile is still reported as 20000 Kbps. Would a reboot of the router and modem tomorrow morning help? mybroadbandspeed is showing similar results 24696 Kbps being the fastest so far.
Re: FTTC Expansion?
06-07-2010 11:48 PM
Re: FTTC Expansion?
06-07-2010 11:53 PM
30046, 29807, 26544, 12796, 21205, 20216, 26628, 25974, 25811, 25688, 24503, 29726, 30829, 30949, 12620, 18830, 19064
So it seems to be dependent on the moment that you run the download. These tests are downloading a 10MB file of random bytes from the same server.
Re: FTTC Expansion?
07-07-2010 12:01 AM
I'll give it a try with a laptop and connection directly into the router tomorrow.
Re: FTTC Expansion?
07-07-2010 12:04 AM
Dave mentioned in an earlier post that the profile will be 20000 in the portal even though it will be 40Mb/sec (or maybe even higher).
Re: FTTC Expansion?
07-07-2010 12:07 AM
Re: FTTC Expansion?
07-07-2010 12:12 AM
However I tend to find the speedtesters can give an artificial result compared to real world downloads. I'll download something in the morning before I go to work when the network is quiet and see what I get.
James
Re: FTTC Expansion?
07-07-2010 9:29 AM
By downloading multiple things simultaneously I managed to get about 36.5Mb/s according to my download monitor
The speed is great and is a world away from the unreliable 3,500 I used to get on ADSL. The speed increase reminds me when I moved from dial-up to ADSL.
@dave - as a matter of interest is the line rate on Plusnet's systems banded between 21,000 and 40,000 in the same way as with lower speeds?
James
Re: FTTC Expansion?
07-07-2010 1:18 PM
The profile is currently set as 100Mbps, in prep for FTTP in just over a week, at the moment there aren't any interim profiles between the old 21Mbps profile and the new 100Mbps profile, there will be when we finish this off but I'm not sure what the steps are yet. Will check it out.
Plusnet Technology
Re: FTTC Expansion?
07-07-2010 1:55 PM
FTTC is due to go live on my exchange Bangor (NIBA) in Sept. In preparation I’ve been looking at the BT Infinity website re the installation requirements.
It states that I need two power sockets next to my master phone socket for the vDSL router?
Can anyone confirm this is indeed a valid requirement? My problem is that my master phone socket is outside my house in a utility cupboard with no power points.
I can get power sockets installed there if this is a definite requirement or I’m wondering is it better to have the master socket shifted inside the house but I assume that’s a BT charge of £128 for “Shifts of residential exchange lines”?
Any guidance appreciated.
Jon
Re: FTTC Expansion?
07-07-2010 2:11 PM
You just need 2 sockets where the VDSL2 modem and router will be located. This does not need to be at the master socket.
If required BT will fit a data extension cable from the master socket to another part of your house (within reason). You then plug everything into the data extension.
James
[Edit: http://www.leyingitout.co.uk/2010/04/my-superfast-fttc-broadband-installation-story/ has a few pictures of an install which you may find interesting]
Re: FTTC Expansion?
07-07-2010 2:12 PM
The faceplate on your existing master socket is replaced with one with two sockets on it - one for your telephone and the other for the VDSL modem. So you don't use your existing extension wiring like you do with ADSL.
I understand that the engineer will install a "data extension" cable for you during the install if required but I don't know whether this is meant for between the modem and master socket or between the modem and router (I expect it's the latter).
Could you put in a cat5e cable yourself between the master socket and the place that you want the VDSL modem to go? You could then connect the new cat5e cable in your cupboard to the master socket and the VDSL modem at the other end. I don't know whether the install engineer would be happy with that (it would work though).
The other way, as you say is to get the master socket moved.
[EDIT] I think the "data extension" can be used for the master socket to VSDL modem (as JEB says) so that will solve your problem.
Re: FTTC Expansion?
07-07-2010 5:02 PM
I ran a speed test this morning: the results are here
Pretty good. Still rock solid as far as I can tell. A wired network connection to the router is obviously the way forward
Re: FTTC Expansion?
07-07-2010 11:16 PM
I have been having a few problems recently. Speeds dropped to between 4-8Mb/s last week, so i had to reset the BT box, which returned my connection to 20Mb/s. Then later that week the connection dropped completely and the only way to restore it was to again reset the BT box again.
Now today after the speed test increase i performed some more tests, the first one was great at 33Mb/s, but all subsequent test have been a bit all over the place between 20-33Mb/s, sometimes dropping to 14Mb/s.
Do you have any advice?
