FTTC Alternate Modems?
- Full Fibre
- FTTC Alternate Modems?
29-06-2011 12:41 PM
Draytek do a VDSL2 router/modem for fibre - Vigor2750 series, so that's a single box, with 4x 1Gb/s LAN ports and 802.11n, UBB for mobile broadband back-up etc
I'm looking for something that is 1: more reliable 2: more features for VPN etc.
- has anyone tried it to replace the OpenReach/Netgear combo?
- would you guys at plusnet support it?
Message 1 of 7
(1,716 Views)
6 REPLIES 6
Re: FTTC Alternate Modems?
29-06-2011 3:28 PM
Another one to look at is the AVM Fritz!Box 7390
I doubt that Plusnet would support or even condone replacement of the BT modem as this is supplied as part of a fully managed service...but I'm sure they can comment on this themselves.
Message 2 of 7
(456 Views)
29-06-2011 3:59 PM
Hi TJN,
With fibre the demarcation point becomes the modem, so you cannot use alternative equipment.
Jojo
Jojo
Message 3 of 7
(456 Views)
29-06-2011 8:39 PM
But if you try it and it works (and you don't get insta-blackflagged by BT), do let us know!
Message 4 of 7
(456 Views)
29-06-2011 9:46 PM
Quote - would you guys at plusnet support it?
Of course not, hardly anyone provides "support" for kit they do not provide. at most you get a 'best effort, this is what we think it might be' kind of support.
Just remember, if it *does* work, you'll have to swap out your kit before BT will even contemplate looking at any issues you have.
Quote and you don't get insta-blackflagged by BT
I would imagine that this is perfectly possible, however idk how much BT would be prepared to implement this to look after their investment. (and if they did, if it even worked...)
Message 5 of 7
(456 Views)
30-06-2011 8:24 PM
Quote from: knowdice Another one to look at is the AVM Fritz!Box 7390
The Fritz box certainly looks good on paper... some info is a bit German..but thanks for the post, wish I'd known about it before I bought a Gigaset VoIP phone system and a USB FAX modem... but I guess if you put all your eggs in one basked it might be a bit more inconvenient when the one box goes down.
not sure if my wife would like the colour scheme though!!
My BT Openreach modem has lasted barely 1 month, they came to change it today (took 4 days to do that) - the sheer inconvenience of no internet for 4 days may outweigh what our dear ISP thinks about using an alternate manufacture router/modem.
Message 6 of 7
(456 Views)
30-06-2011 10:33 PM
Quote the sheer inconvenience of no internet for 4 days may outweigh what our dear ISP thinks about using an alternate manufacture router/modem.
Unless BT refuse to provide you with a fibre service.
Then it wont outweigh the downtime.
Message 7 of 7
(456 Views)
