Does Plusnet Need To Change Settings So I Get FTTP Speed
- Full Fibre
- Re: Does Plusnet Need To Change Settings So I Get ...
- « Previous
- 1
- 2
- Next »
Re: Does Plusnet Need To Change Settings So I Get FTTP Speed
01-01-2023 4:54 PM
01-01-2023 4:55 PM
Connect the primary node WAN port to the ONT.
I refer to the internet connection, hopefully this is the correct picture. Page 17 of the attachment
The usnername would be [email protected] and the password (as used for the member centre) You do not need a VLAN setting if there one.
I would expect openreach would say you agreed to the position of the ONT, but you try asking for it to be moved.
HTH
01-01-2023 5:13 PM
So if I am attaching the node to the ONT what about the router?
Sorry if a daft question but all this is new to me.
Angus
01-01-2023 5:16 PM
Sorry I should have said.
The primary mesh node will be configured as a router so the Hub is no longer required.
Dan
01-01-2023 5:17 PM
you don't need it
01-01-2023 6:17 PM
01-01-2023 7:06 PM
I will leave and monitor it like this today. But am thinking best bet is getting the Ethernet cable to take the router the to front room.
At least I have options now and don’t feel trapped. Thanks for all your help. Angus
02-01-2023 7:59 AM
I find it rather strange there is no improvment of speed when the mesh is connected directly to the ONT, I would have expected around the same speed as you had when the Hub Two was directly connected.
What etherent cable are you using between the ONT and mesh device or powerline adapter?
Dan.
02-01-2023 9:48 AM
The problem was the cables. I had not appreciated some were not the correct spec.
I have now managed to set up the Node to the ONT and am getting the correct speed.
I may get an extension lead so use the router in the front of house later on but happy with this just now.
Apart from the fact this means wiring up an extension Ethernet thru the house are there any advantages to using the router 2 as opposed to the Node?
Angus
02-01-2023 10:01 AM - edited 02-01-2023 10:03 AM
This is good news.
The Hub two has improved wifi performance to previous plustnet supplied hubs, so I would use the device which gives the best wifi performance for your home. If you need to use any wired devices then the Hub Two will be best, you can still use the mesh node as before if that helps with wifi across your home.
Dan.
- « Previous
- 1
- 2
- Next »
- Full Fibre
