Distance between ONT box and router?
craggyducks
I am about to upgrade to Full Fibre 145 and I am being told on the ordering screen that the ONT box and the router need to be close together. However I think the ONT box is going to be installed on the opposite side of the room to where my Hub 2 router will be. I was thinking of buying a 5 metre ethernet cable to cover the distance between the two with each device plugged in at opposite sides of the room.
Can this be done without causing any issues?
5 REPLIES 5
Fixes: 579
Re: Distance between ONT box and router?
@craggyducks
In a word, yes!. The maximum length of an ethernet cable is 100m. Just make sure that you get a cat5e or better (cat6 or 7) cable.
Fixes: 115
@craggyducks
Unlike FTTC, routers do not need to be near the Full Fibre ONT as they connect via an ethernet cable.
I would hold off buying any new cables until such time as the ONT is on the wall and you can "see" clearly what is required for you. Note - the is a certain leeway as to where the fibre comes into your property and the location of the ONT. The latter does need a power source. With my install, the fibre came in at the same point as the copper wire but the fibre cable was then run round to the back of the front room. It was stapled to the skirting board.
You discuss it with the installer on the day.
craggyducks
Thank you both very much, I feel reassured now and can press on with my order.
mwwagain
Fixes: 4
This is only because they only supply a tiny length of dubious quality ethernet cable with the Hub, and also assume you'll use the same double outlet mains socket for both.
craggyducks
Sorry, just seen this. I've bought a certified 5 metre Cat 6 cable ready. Thank you.
