Database error?
Kukorica
Database error?
I wanted to join PlusNet as I only have mobile broadband at the moment.
I checked a couple of of months ago and back then there were full fibre offers for my address with PlusNet.
Now there is none, only part fibre at very low speeds of 24-26Mbps.
Openreach broadband checker states that there is full fibre available available at my address, but on the PlusNet website it's not available.
Out of 7 of my neighbours, the PlusNet website showed available for 3 addresses and 4 came back unavailable.
PlusNet customer services were equally puzzled. I know it's not their fault as they can only say what they see in their computers, but I seem to be stuck at the moment.
Please advise if you have any idea many thanks
7 REPLIES 7
krusty
Re: Database error?
what does
https://www.broadbandchecker.btwholesale.com/#/ADSL/AddressHome
give you?
mine which has fttp has
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install Process
WBC FTTP Up to 1800 Up to 220 -- Available 1 Stage
if you can't get fttp it will show this
FTTP on Demand 1000 220 -- Available --
Kukorica
Re: Database error?
Kukorica
Re: Database error?
Fixes: 118
Re: Database error?
@Kukorica
Basically there's a network capacity issue somewhere. Until that's cleared you'll not be able or order Full Fibre. The PN system checks with OR to confirm availability - with the waiting list the system is saying No.
Is SOGEA available from PN? You could get that to keep you going and then ugrade to Full Fibre when it becomes available.
Fixes: 586
Re: Database error?
@Kukorica
@bmc is probably correct , its likely a capacity issue. It COULD be a database error so you could try asking PLusnet to raise an ORDI request to Openreach to check why its 'Waiting list' , especially if it shows as available for other neighbours.
Kukorica
Re: Database error?
Many thanks for your replies, much appreciated. I will try and ask Plusnet to raise on ORDI request to Openreach and see what happens
Fixes: 118
Re: Database error?
@Kukorica
Using the Address version of the following check your 3 neighbours who are showing as Full Fibre available.
https://www.openreach.com/help-and-support/full-fibre-broadband-installation-checklist
Below the results window will be a line of narrative on FTTP. Does it say that an ONT is installed and, if so, is it active?
It could be they got a service before the capacity issue hit.
