Database error?
- Full Fibre
- Re: Database error?
Database error?
2 hours ago
I checked a couple of of months ago and back then there were full fibre offers for my address with PlusNet.
Now there is none, only part fibre at very low speeds of 24-26Mbps.
Openreach broadband checker states that there is full fibre available available at my address, but on the PlusNet website it's not available.
Out of 7 of my neighbours, the PlusNet website showed available for 3 addresses and 4 came back unavailable.
PlusNet customer services were equally puzzled. I know it's not their fault as they can only say what they see in their computers, but I seem to be stuck at the moment.
Please advise if you have any idea many thanks
Re: Database error?
an hour ago
what does
https://www.broadbandchecker.btwholesale.com/#/ADSL/AddressHome
give you?
mine which has fttp has
| Featured Products | Downstream Line Rate(Mbps) | Upstream Line Rate (Mbps) | Downstream Range (Mbps) | Availability Date | FTTP Install Process |
| WBC FTTP | Up to 1800 | Up to 220 | -- | Available | 1 Stage |
if you can't get fttp it will show this
| FTTP on Demand | 1000 | 220 | -- | Available | -- |
Re: Database error?
an hour ago
This comes up, it says waiting
Re: Database error?
53 minutes ago
This is weird
Re: Database error?
41 minutes ago - last edited 41 minutes ago
Basically there's a network capacity issue somewhere. Until that's cleared you'll not be able or order Full Fibre. The PN system checks with OR to confirm availability - with the waiting list the system is saying No.
Is SOGEA available from PN? You could get that to keep you going and then ugrade to Full Fibre when it becomes available.
Re: Database error?
37 minutes ago
@bmc is probably correct , its likely a capacity issue. It COULD be a database error so you could try asking PLusnet to raise an ORDI request to Openreach to check why its 'Waiting list' , especially if it shows as available for other neighbours.
Re: Database error?
28 minutes ago
Many thanks for your replies, much appreciated. I will try and ask Plusnet to raise on ORDI request to Openreach and see what happens
