DLM Reset
- Full Fibre
- DLM Reset
DLM Reset
11-12-2025 12:25 PM
Hello
I have had Plusnet FTTC for a while after switching from TalkTalk and the speed had always remained stable until a few days ago, the hub suddenly turned orange and went on a loop of resetting every few minutes for a couple of hours. The diagnostic bot found a fault with the line but when I tried calling I couldn’t get through to anyone. Is it possible to have the DLM reset as the speed has now plummeted down to less than half what I was getting previously and most services like Netflix are now unusable due to constant buffering
Message 1 of 3
(575 Views)
2 REPLIES 2
Re: DLM Reset
11-12-2025 12:28 PM
You clearly have a fault-use the bot to report it: https://www.plus.net/help/report-a- problem/
As of April 24th2026, I am now utilizing Sky Broadband, which offers full support for IPv6 addressing. Broadband Status page https://stats.uptimerobot.com/i06TwWNbhx
https://gaytxtbudzuk.co.uk/ my website
Message 2 of 3
(568 Views)
Re: DLM Reset
11-12-2025 12:33 PM
@Bond02 If the bot found a fault - what was the fault, and what was the suggested course of action? A DLM reset without a fault resolution is pointless.
