D/L slow speeds and IP profile halved
PhyllisTyne
Speeds have dropped markedly over last couple of weeks. Just ran BT speed test and additional diagnostics. speed and IP profile about half what should be (see attached). How do I get this fixed please. hope it isn't another issue with this dodgy line!
PT
13 REPLIES 13
PhyllisTyne
Re: D/L slow speeds and IP profile halved
Further diagnostics attached
Fixes: 353
@PhyllisTyne How does your phone sound? And can you post your router stats - which one do you have?
PhyllisTyne
phone sounds fine. I have HH6 but routerstats not east to get as is in modem only mode with TP-Link mesh M5 doing the routing.
PT
Fixes: 353
Ok - I would raise a fault - you are below even the 'Impacted' Hand-back threshold, so there is a problem.
PhyllisTyne
I think so but thanks @jab1
Hoping staff on here might take a look for me before I raise a fault.
Fixes: 353
They might, but there's only two of 'em ATM. Smiley
PhyllisTyne
I'll give them a day or two. not urgent since retired. Everything is much slower 😂
adam945
Fixes: 113
Thanks for getting in touch @PhyllisTyne
Bit of a strange one this, there was one drop on the line which occurred on 28/01/2022, which resulted in the sync speed plummeting. The DLM profile looks fine, but our internal L2TP profile appeared to be stuck at around 28Mbps.
I've just reset this on my end, can you run another speed test (preferably wired) in an hour or so and let me know how you get on?
 Adam
 Plusnet Help Team - Leeds
PhyllisTyne
adam945
Fixes: 113
Thanks for getting back to me @PhyllisTyn, I reckon we ought to raise this with Openreach now as sync speeds on our end are still really low. I've just created a ticket on the account which we'd need you to respond to, stating your availability for an engineer visit.
Let me know when you've responded and I'll get it raised. Smiley
 Adam
PhyllisTyne
Thanks @adam945 . Just responded by SMS. Can do any time next week bar Wednesday afternoon.
PT
adam945
Fixes: 113
Thanks a lot for that, I've just raised the fault on the open ticket and have popped the appointment details on there too. Let me know if you have any further questions at all. Smiley
 Adam
PhyllisTyne
Thanks. Fingers crossed they will sort once and for all this time but I suspect on FTTP will do that.
