Cannot connect to Ubisoft server
Joaniem1109
Trying to play UNO online using Nintendo Switch but kept getting unable to connect to Ubisoft server. Have tried on my sons Virgin Wi-Fi and it works ok. I am assuming it is a Plusnet issue. Can anyone help?
7 REPLIES 7
adam945
Fixes: 113
Re: Cannot connect to Ubisoft server
Hello @Joaniem1109
Thanks a lot for getting in touch and I'm sorry to hear that you're having issues with this. I'm not actually aware of any issues we're having with connecting to Unisoft servers, and I myself have been able to recently, on Plusnet broadband.
It sounds like an easy fix, but if you'd like to try turning your router off for 65 minutes, which will assign a new IP address to your connection, give that a go and let us know how you get on.
 Adam
 Plusnet Help Team - Leeds
Joaniem1109
Hi Adam, thanks for reply. I did  as suggested and turned the router off for over 65 minutes. Issue still the same when I try to go to online play UNO on Switch. Am attaching screen print of error message. Thanks Joan
adam945
Fixes: 113
Thanks for letting me know @Joaniem1109 and I'm sorry to hear that it didn't work. Are you able to forget your network on your switch? Then try re-connecting to the router?
 Adam
Joaniem1109
Hi Adam,
Thanks again for your reply.
I deleted the network settings on the Switch and reconnected to the router but still getting the same error message.
Joan
adam945
Fixes: 113
That's super odd @Joaniem1109, your connection does appear fine from our end, we don't block or restrict access to specific servers either. Have you contacted Ubisoft for support on this matter?
 Adam
bobpullen
Fixes: 331
@Joaniem1109 it looks like you have our Safeguard parental control filter enabled. Have you tried temporarily disabling it and restarting your router to see if it helps? It could be that the Ubisoft servers are being blocked.
https://www.plus.net/my-account/safeguard/
Joaniem1109
Hello Bob,
Thanks for the reply. Yes you were right about Safeguard, I have switched it off and UNO is now available for online play.
Thanks again to all at Plusnet Support for your assistance.
Joan
