Constant Wif Drop Outs and Wifi connection with no internet.
Matt72
Re: Constant Wif Drop Outs and Wifi connection with no internet.
@jab1 it's 4.7.5.1.83.8.263 thanks.
And I will take this opportunity to thank @Mustrum as I neglected to in previous post.
Fixes: 334
@Matt72 There is a new version of the F/W (.289.1.3 I believe) being rolled out for the Hub1, but whether that will solve your specific problem I would not like to say.
Matt72
Thanks for that info @jab1
Fixes: 1,641
Thanks for getting back to us @Matt72
I'm sorry to see you're having issues with your connection. If @bobpullen's around he may be able to update the firmware in your router or if you post in the topic Here he tends to drop by there every so often.
