Router solid green light
Sean118
The internet went off last Sunday and it took a while for it to come back on. The connection has been poor for the past week, but today it has gone off completely. Tried resetting the router but now it's stuck on a solid green light and it doesn't show up on the list of available connections. Is the router kaput? If so how do I get another one?
3 REPLIES 3
Mustrum
Fixes: 81
Re: Router solid green light
Have you checked the phone line?
Or done any troubleshooting? The Help Tab at the top of the page will guide you through.
Sean118
Yes I text Plusnet for them to check the line, they said it was fine (I asked them to ring me back but they haven't). And it rings fine too. I just switched the router off and on again and it stays on green permanently (it used to cycle through red, orange, blue then green). Does this mean it's now broken?
Fixes: 1,662
Thanks for your post @Sean118 and welcome to our Community Forums.
I'm sorry to see you're having issues with your router.
I can see we tried to ring you yesterday afternoon, but we couldn't get through.
Can you try a factory reset of your router by pushing a paperclip into the reset pin hole at the back for 20 seconds?
Let us know how it goes.
