Connection dropping after power cut
AB28
Hi, After a 7 hour power cut today my internet connection keeps dropping.  Could the power cut have damaged the router or could it be that the signal takes a while to come back properly?
14 REPLIES 14
Fixes: 377
Re: Connection dropping after power cut
The chances are the power cut could have upset the router. It may be an idea to reset it - once.
Fixes: 1,661
Hi @AB28
I'm sorry to see your connection's dropping after a power cut.
Line tests aren't showing any issues and things look to be stable since last night.
Are you still having problems?
Strat
Fixes: 565
Moderators Note
This topic has been moved from ADSL Broadband to Fibre Broadband.
AB28
Hi, I did a reset last night and the line seems now to be stable.
Fixes: 1,661
@AB28
Glad to hear that!
Let us know if you have any further issues Smiley
AB28
Hi, I thought all was well earlier but the connection has dropped again and is poor.
adam945
Fixes: 113
Hello @AB28
Thanks a lot for reaching out again and I'm sorry for the issues you've been having. A visual radius shows a huge disconnection over the weekend, which I can't see the cause of retrospectively, however the connection now appears to be back to normal. Can you please describe the problems you're having?
</ div>
 Adam
 Plusnet Help Team - Leeds
AB28
Hi, there was a power outage down my road Saturday night and most of Sunday.  Since the power has come back on my iPad keeps disconnecting from the WiFi.  I think the power outages must have damaged the router.
adam945
Fixes: 113
Thanks for getting back to me @AB28
Have yiou tried giving the router a Factory Reset? This will re-configure the wireless channels on it to those best suited for your environment. If you'd like, I can go into the router settings remotely and make a few adjustments on there, which are known to improve your wireless connectivity. This will drop the WIFI on your wireless devices  for a moment or two though, let me know. Smiley
 Adam
AB28
Hi, I did try the putting the pin in the small hole at the back of the router, is that factory resetting?  If you could remotely go to my router settings that would be good.🙂
adam945
Fixes: 113
Yeah that's to give the router a factory reset @AB28 Smiley
Don't worry about changing anything else on your end though, I've just gone into the router and have tweaked a few settings which are likely to improve your wireless service.
I’ve run a little tool on our end called Smart Wireless, this scans your local area and adjusts your router’s WIFI channels to those best suited for your environment. I’ve also split the SSID’s on your router, giving you the choice of whether to connect to the 2.4GHz or 5GHz wireless band.
The general rule is thumb when deciding which band to connect to:
2.4GHz – Slower WIFI speeds, but covers a greater range
5GHz – Faster WIFI speeds, but covers a smaller range.
So for instance, if your TV is in the same room as the router, I’d connect it to the 5GHz band, giving it faster speeds for streaming etc.
Information of splitting, or turning off the 5GHz band can be found here:
https://community.plus.net/t5/My-Router/Hub-One-5GHz-WiFi-issue/m-p/1696363
See how you get on for a few days and let us know how it goes. Smiley
 Adam
AB28
Thank you for looking into this.  I’ve swapped over to 5GHz and will give that a go for a while and if no good will swap back.  I’ll let you know in a few days how I get on.
AB28
Hi, my connection problems are now resolved, thank you very much for all your help 😀
adam945
Fixes: 113
Really glad to see that that's done the trick @AB28
Feel free to reach out if you have any other issues at all. Smiley
 Adam
