Change to fibre
- Full Fibre
- Change to fibre
Change to fibre
yesterday
Re: Change to fibre
yesterday
@Tinacorr7 Which Hub do you currently have, and which Full Fibre speed are you looking at?
Re: Change to fibre
yesterday
Re: Change to fibre
yesterday
Hub1 or Hub2? And you are aware you will lose the phone if you switch - which you will do in the next 18 months or so anyway?
Re: Change to fibre
yesterday
Re: Change to fibre
yesterday
Not a big problem - as far as I know, the Hub1 can handle the lower speed tiers, but the Hub2 is better all round. For information, the H1 has its lights at the bottom, the H2 has them in the centre 'front'.
Re: Change to fibre
yesterday
You can check here which router you have.
https://www.plus.net/help/broadband/router-setup-guides/
If you have a Hub1 you'll be offered a Hub2 for £6.99 postage and packing.
