Cannot connect to National Lottery
Sterling
Whenever I try to connect to the National Lottery I get an error message saying it cannot connect as it appears I'm out of the country. Any ideas how to resolve this,
Regards
3 REPLIES 3
Mustrum
Fixes: 81
Re: Cannot connect to National Lottery
Make a note of your public IP address.
Switch the router off for 20-30 mins.
Switch it back on, check to see if you have new IP address and try again.
You may have to switch it off over night.
That's the quick fix, reporting the fault to PN and National Lottery is the long term fix.
Fixes: 466
@Sterling
Another option is to install a VPN such as Windscribe, who will give you 10GB per month free data. Set the destination IP address to UK. I have one installed on Chrome for occasional use, normally using Firefox for every day browsing etc.
Sterling
Thanks for the replies. I have disconnected router for 2 hours but still have same IP address so I will disconnect overnight. Like Baldrick I'm using Firefox.
Regards,
